22858 Discussions
Screen flickering when cell phone 60-70cm away
JMeye91
in our office we have 2 PCs (one HP EliteDesk and one Lenovo ThinkCentre, both with an i5 6500) with the same screen flickering problems which seemed to be occuring randomly. Both having 2 screens connected via DisplayPort.
Yesterday i found a way to reproduce the flickering reliably with both PCs:
if I take my mobile and force it to use a 2G* connection and make a call (or let someone call me, doesn't matter) and put the mobile with an active call closer than ~70cm to the screen it starts flickering.
the closer i put the mobile to the screen the worse it gets (from flickering lightly to to going complete black).
*the mode which creates these buzzing noises in a speaker close to an mobile with an active call. 3G connections do not show this problem.
Amy_C_Intel
Hello, @j_m:
So, the issue seems to be related to an external element. If you move the phone away, does your PC flicker?
JMeye91
Hi Amy,
it depends on the distance to the screens. the closer i put my mobile to them, the worse it gets.
the flickering starts if i put my active mobile closer then 60 to 70cm to the screens, further away is no problem.
Amy_C_Intel
This can be addressed as en external issue, from your description the graphics controller and the Intel® HD Graphics driver are working fine, so the issue is regard to your phone not the graphics controller. Maybe it's just your phone and some kind of interference.
Bryce__Intel
Closing this as HW issue. This is not related to Intel Graphics, please seek assistance from the OEM.
