22680 Discusiones
Screen going black and restart with ARC A750 when playing video games
Matthew21
Principiante
1.003 Vistas
I have been using Intel Arc A750 LE for 5 months. When playing video games the computer stops working,screen goes black and restarts itself, giving no display output when the computer restarted.The games this happens are the games that requires gpu and cpu workload.
To replicate this this issue just play one of the games that is new and requires gpu and cpu workload for 1 hour or less and the computer suddenly crashes.
The things i tried to stop this:
-Downgraded to the older version where it didn't crash (Didn't work)
-Reseating RAM, GPU (Didn't work)
The driver version is 32.0.101.6325
I have a AOC G2260VWQ6 monitor 1920x1080 60 HZ
Before this i had an RX550 and didn't had these issues.
0 kudos
8 Respuestas
VonM_Intel
Moderador
948 Vistas
Hi, Vokan.
Thank you for posting in our Community and for the detailed information on the issue and the troubleshooting steps you've already tried. Some users have reported game crashes with Intel® Arc™ graphics, especially the A770 model, including DirectX errors, graphical issues, and specific game crashes. Since your system crashes and restarts under high GPU/CPU load, let’s dig a little deeper to figure out the cause:
  • Do you see any error messages when the PC restarts (Event Viewer, BSOD, debug LEDs/beeps)?
  • After restarting, does the display return automatically, or do you need to power cycle the PC?
  • Have you checked if your PSU provides stable power under heavy load?
  • Have you tested other Intel Arc driver versions besides 32.0.101.6325?
  • Have you used DDU to fully remove and reinstall the GPU drivers?
I know it’s a lot of questions, but identifying the root cause sometimes takes a bit of digging.
Have a nice day!
Von M.
Matthew21
Principiante
937 Vistas
--Do you see any error messages when the PC restarts (Event Viewer, BSOD, debug LEDs/beeps)?
-In event viewer it only says the system was restarted or shutdown incorrectly, about BSOD it did not give me that but i have crash logs.
--After restarting, does the display return automatically, or do you need to power cycle the PC?
-I need to power cycle in order to get display signals.
--Have you checked if your PSU provides stable power under heavy load?
-I have a 500W High Power 80+ PSU I did not test it for stable power.
--Have you tested other Intel Arc driver versions besides 32.0.101.6325?
-I tested all of the drivers in the Intel Arc Driver's site.
--Have you used DDU to fully remove and reinstall the GPU drivers?
-Yes I did use DDU to fully remove and reinstall GPU drivers.
VonM_Intel
Moderador
886 Vistas
Hello, Vokan.
I appreciate that detailed information on the issue you're experiencing with your Intel Arc A750 LE. Based on the symptoms and steps you've already taken, here are my recommendations moving forward:
    1. Go to the game settings located in-game (steps may vary per game).
    2. Go to video settings.
    3. Go to Render API
    4. Choose Vulkan or Direct3D11 instead of Direct3D9.
    5. Apply and restart the game.
Additionally, you can also refer to our article outlining the troubleshooting steps here: Screen Turns Black a Few Minutes after Playing Game with Intel® Arc™ Graphics
Please let me know the result.
Von M.
Matthew21
Principiante
867 Vistas
I did check the temperatures of the GPU but i was not exceeding 90°C.
I did reinstall the latest driver but the issue is still ongoing.
VonM_Intel
Moderador
840 Vistas
Hello, Matthew21.
Thank you for the update. Since your GPU temperatures are within a safe range and reinstalling the latest driver didn’t resolve the issue, we’ll need to investigate further. I’ll need to conduct additional research on this issue and will post an update in this thread once I have more information about this matter.
Von M.
VonM_Intel
Moderador
808 Vistas
Hello, Matthew21
Thank you for your continued cooperation. To help me further isolate the root cause of the issue you're experiencing, could you please provide the following details:
  1. Which specific game(s) are triggering the black screen or crashes?
  2. Have you tested the system with a different monitor to rule out display-related factors?
  3. What type of video connection are you currently using (e.g., HDMI, DisplayPort)?
  4. Additionally, your system is currently running BIOS version F66. We recommend updating to the latest version, F67g, as it may include critical stability improvements. You can find the update on your motherboard manufacturer’s support page.
Once I have this information, I’ll be better positioned to guide you with next steps.
Von M.
VonM_Intel
Moderador
661 Vistas
Hello, Matthew21.
Von M.
VonM_Intel
Moderador
628 Vistas
Hello, Matthew21.
As I have not received any further updates from your end, I will proceed to close this inquiry. If you require additional support, please don't hesitate to submit a new question, as this thread will no longer be monitored.
Von M.
Responder
