22850 Discussions
Screen tainted orange an night light doesn't turn off
Hossain_Aryan65
My screen is tainted orange and night mode can't be turned off! I tried to install an old driver, from the latest version. Still it didn't work 😞
AndrewG_Intel
Hello @Hossain_Aryan65
In order to check this behavior, could you please provide the following information?
1- Is the system a laptop or a desktop? If this is a laptop, is the behavior occurring on the built-in display, on an external display, or both? If this is a desktop, is the behavior occurring on a specific/particular monitor or on several/different monitors? Please provide details.
2- Is this a new system? Did the computer work fine before or are you experiencing this issue since the first day that you have the device?
3- If this worked fine before at any moment, were there any recent hardware or software changes that might relate to the point when the issue started? (For instance, Windows®, driver, or software/game updates?)
4- Could you please provide details about the current Night light settings on your system? You may also provide some screenshots from Windows Settings >> Display >> Night light settings to show the current configuration.
5- Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
  • Download the Intel® SSU and save the application on your computer
  • Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click Next and click Save.
  • Once you have saved the file (.txt file), please attach it to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
AndrewG_Intel
Andrew G.
Hossain_Aryan65
It was an issue with the night light in Windows. I resetted my PC and it is fine now. Thanks
AndrewG_Intel
Hello Hossain_Aryan65
Thank you very much for your response and for your feedback. Perfect!, we are glad to know that you managed the solve the problem with the Windows* Night light feature.
Since the issue is solved, we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
