23259 Discussions
Skull Canyon NUC6i7KYK - Rendering issues with FIFA 16
BBern4
I was trying to play FIFA 16 with Intel NUC Skull Canyon NUC6i7KYK, but unfortunately all players are either rendered completely black or very dark. It is impossible to play. I tried all various display configurations, but none was working. I am using Windows 10 64 BIT. When I lock the frame rate to 60 fps the players become even red. Is there anything i can do regarding to the rendering issue? I have a 4k monitor connected via HDMI 2.0. Is it worth trying to connect via DisplayPort cable?
see also:
http://answers.ea.com/t5/Technical-Issues/Fifa-16-PC-all-players-rendered-black-with-Intel-Iris-Pro/m-p/5375091# M58504
http://gaming.stackexchange.com/questions/267780/fifa-16-pc-all-players-rendered-black-with-intel-iris-pro-graphics-580
Hi berndberner,
Excuse for the delay on the answer.
In regards to your issue, I understand you are trying to use a resolution of 3840x2160 @ 60Hz; I review the TV specifications and the maximum and recommended resolution is 2560x1440@60Hz.
I suggest you to verify manually on the TV settings, which the maximum resolution supported is. If it does, please send me the full model of the TV and the current BIOS version.
AOC Q3277PQU
http://aoc-europe.com/en/products/specification/q3277pqu http://aoc-europe.com/en/products/specification/q3277pqu
Mike C
BBern4
Dear Mike,
thanks for your response. No, my monitor is U3277PQU not Q3277PQU. It supports 3840x2160 as you can see here http://aoc-europe.com/en/products/u3277pqu# product-detail-technical U3277PQU AOC Monitor - AOC
Anyway - I was trying even in the lowest resolution possible - 1280 x 720 - and is not working. Same issues...
BBern4
Forgot the bios version; KYSKLi70.86A.0034.2016.0503.1003.
And the video bios version: 1037 PC 14.34 12/23/2015 19:33:49
MHek
Hey,
I have exactly the same problem with my Intel® Core™ i5- 6267U with the integrated Iris 550. I have tested several drivers but none of them work. Will there be a new driver released soon or is there any other solution to the Problem?
Best regards
Hi All,
I would appreciate if you can give me a update of the NUC performance.
Mike C
