I built a new Skylake system with a 6700K and a Asus Z170-Deluxe. The mainboard converts a displayport out to a HDMI 2.0 out with a HC2800 chip.The OS is Fedora 23 with rawhide kernel 4.4 and xorg-x11-drv-intel-2.99.917-16.20150729.fc23.x86_64 driver. I have connected my TV to the HDMI out and I want to set the display to 3840x2160@60Hz. Using xrandr to set the resolution only produces an error on the TV: "Not supported". Unfortunately my TV only supports this resolution with chroma compression in a YCbCR420 color space, which works on a different PC with a nVidia card.
How do I get this setup to work in 3840x2160@60Hz with integrated graphics?
Does it even work in Linux? From http://forum.asrock.com/forum_posts.asp?TID=1203&title=half-solved-hdmi-20-with-z170-gamingitx-ac this thread on a Asrock board with a similar configuration I gather it's possible to set up this resolution with YCbCr420 in Windows.
Thanks in advance.
Hello, boost:
In order to address this issue I would recommend to post it on the https://01.org/linuxgraphics/forum Forum | 01.org.
Amy.
