23266 Discussions
SoC driver for Intel Atom
toondook
System-Windows 8.1 64 bit
CPU-Intel Atom X5-Z8300
При попытке установить драйвер для видеоядра получаю ошибку о несоответствии устройства с минимальнымии системными требованиями. Различнные средства автопоиска драйверов также не справляются с задачей.
ShivaniK_Intel
Thank you for posting your question in the Intel Community Forums. This is an English-only forum. I translated your question via Intel secure translator which generated the following
System-Windows 8.1 64-bit
When I try to install the driver for the video core, I get an error about the device not meeting the minimum system requirements. Various means of auto-search for drivers also do not cope with the task.
Is this what you wanted to ask?
Thanks & Regards
Shivani
toondook
DeividA_Intel
Hello toondook,
Thank you for posting on the Intel® communities. I understand you are having issues installing the graphics drivers.
Deivid A.
DeividA_Intel
Hello toondook,
Thanks for your patience, To continue with the investigation I will need the reports from the Intel® System Support Utility (Intel® SSU) and provide the link you using to get your drivers.
Deivid A.
DeividA_Intel
Hello toondook,
Thanks for your response and the report. To continue further I will also require a link to the website where you tried to get your drivers, this is because you mentioned "When I try to install the driver for the video core". Which driver is it? Where are you getting it from?
Deivid A.
toondook
https://www.intel.com/content/www/us/en/download/18369/intel-graphics-driver-for-windows-15-40.html I tried this one. Also i used a programmes like DriverPack Solution, Driver Booster 11 and Intel Driver and Support Assistant.
DeividA_Intel
Hello toondook,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello toondook,
Thanks for your patience. In order to continue with the support, please confirm the following:
1. What is the error that you are getting? Can you take a picture?
2. Are you able to install the driver from the computer manufacturer's website?
3. Did you try to get the driver from this website: https://www.intel.com/content/www/us/en/products/sku/85474/intel-atom-x5z8500-processor-2m-cache-up-to-2-24-ghz/downloads.html
Deivid A.
DeividA_Intel
Hello toondook,
I am just following up to confirm if you had the time to read my previous post and I would like to know if you can confirm the details mentioned before.
I will be waiting for your next response.
Deivid A.
DeividA_Intel
Hello toondook,
I was checking your thread and noticed that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
