23254 Discussions
Some weird things about hd 530
why does it laod on 80-89 percent in csgo and other games too? when framerate is unlimited..., very seldom it can laod on 95-99 but it is very seldom..
And why when im playing minecraft it sometimes shows to me black squares with small green dots.. and sometimes it crashes after this..
Gpu core clock is SO instable, 850-1050... no thing about 1050. (It is stable 1050 when game somehow laods it on 95-99 percents
Temps are normal, it's not high than 44 degree Celsium
Hello speecbeen:
In regard to your inquiry, about the high cpu utilization, I just wanted to let you know that this is related to the coding of the software or application. Each software/application is develop to manage and handle the resources available in the CPU, but this will depend on the algorithmic complexity and the programming language used, software/application might use all these resources in order to perform as expected. Getting 100% of CPU utilization on some software/applications does not mean that your processor is faulty, it just means that the software/applications is using all the resources available in the CPU. You have to consider that when running a game there are background processes that are also handled by the CPU, so utilization can be 70% game and 30% of background processes(this is just an example). One more thing that you have to consider is that your processor is meant to reach 0% to 100%, and as long as your system does not crash or freeze it should be fine.
About the problem with Minecraft, and the Intel® HD graphics 530, please try the following driver, it is version 4501 that latest for that graphics controller:
https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
If after that the problem persists, then we will need to verify a few details:
What is the model of the board?
What is the model of the processor?
If this is a laptop, what is the model of it?
Alberto
I have downlaoded that latest driver and it fixies my problem with minecraft and it even abit improve laod of gpu in CSGO...
I found an interesting fact, that if I play csgo with fullscreen mode, gpu laods at 85-92 percents with fps drops sometimes,
but if turn on window mode, gpu will laod at 99-100 stable precents without any freezes and fps drops!
It also works for Minecraft.....
but with Minecraft it works only if i have the game minimized, then gpu always is laoding at 100 percent 😕 there is something wrong
my comp characteristics:
Board: MSI H110M PRO-VH (MS-7996)
Processor: Intel Core i5-6500
Windows 10 home (10.0.14393 Build 14393) x64
And my processor isn't high utilizing its laod usually not high than 60. I asked about his base clock, it is unstable.. 99.62-99.91 and it scare me, just in my laptop processor's base clock is stable, but my processor has varying base clock! It is not stable 99.78 for example, it's 99.62, (66,68,71,73,78,81,86,91) and i think it's going down. I want to stabilize it, how can i do it? or it broken?
Hello Ingresed:
Since Minecraft only works with minimized window, we can try the following driver, it belongs to MSI the manufacturer of the board and it might fix this problem, please choose the vga driver:
https://www.msi.com/Motherboard/support/H110M-PRO-VH.html# down-driver&Win10 64
Also, a BIOS update will be helpful, please try version 2.8, it is the latest one according to the site:
https://www.msi.com/Motherboard/support/H110M-PRO-VH.html# down-bios https://www.msi.com/Motherboard/support/H110M-PRO-VH.html# down-bios
Also, we can try the drivers from Microsoft by doing a Windows update.
In regard to your inquiry, it is expected for the base clock of the processor to go high a low, depending on the load of work and the processes that are running in the background, specially if you are playing a game that has a high demand on graphics, but that does not mean the processor is defective, if the temperatures are not high as long as the PC does not throttling, getting freeze or going off by itself it should be fine.
We do have a tool to test he processor, it does an overall test, and if the processor passed the test it should be fine:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Besides that in regard to the game, you can also use the following link:
http://www.minecraftforum.net/ http://www.minecraftforum.net/
Alberto
Hello Ingresed:
I just wanted to check if the information posted previously was useful for you, and if the problem with Minecraft was resolved or if it still persists?
Alberto
