22963 Discussions
Sorry, we didn't find any supported Intel drivers or software.
MOKJANG2
After using the intel auto graphics driver updater, there's a text like this.
my computer specification:
Windows 10 pro 64bit
NVIDIA GeForce GTS 250
If you need any other information, pls reply.
※ Pls note that sentences may be insufficient using a translator.
AlHill
The Intel Driver and support tool does not provide updates for nvidia graphics.
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
n_scott_pearson
I would also add that, in Desktop systems, the presence of an add-in graphics card will, by default, cause the Intel processor graphics engine to be disabled. In this case, you aren't going to be able to install any of the Intel HD Graphics driver packages. I would also add that, when these packages fail to install, their error messages may be confusing and not related to the issue at hand (this issue has been reported and will be fixed eventually).
