23851 Discussions
Sparkle Intel Arc B580 GPU Noise (Software Problem)
FreitasM545
After a few weeks, I came back to the Intel community. My issue is a repetitive noise that was talked about in two different (made by me) posts. Post 1 & Post 2
The Intel answer to this issue was that it was a faulty hardware and that I should change my GPU under warranty. Even when explaining the problem completely, it is clear that this only happens when the Intel Graphics Software is set to Advanced Fan Tuning.
Now, after having the trouble of talking to the store I bought the GPU from and exchanging it for a new one, the problem persists. So, once again, I say to Intel, this is a SOFTWARE issue and not a hardware one.
I think Intel is on a great path with the GPU division, but it needs to definitely start testing the drivers better and come up with solutions, so we buyers don´t have to be the ones testing them for you.
If you have any solutions for this, they are welcome. In the meanwhile, I will plug my headphones so I don´t hear this thick thick thick...
PatrickV_Intel
Hi FreitasM545,
Thank you for reaching out to the Intel Community Forum!
To help us investigate your issue further, I reviewed the two previous threads and saw that a previous moderator recommended contacting the Original Equipment Manufacturer (OEM). Have you had a chance to get in touch with them?
Looking forward to your update so we can assist you better!
Patrick V.
FreitasM545
Hi Patrick V,
Von M. on the last message of the thread, told me to contact the retailer since this was supposed to be a hardware-related issue. Unfortunately, as mentioned above, the GPU got replaced for a brand new one and is still currently doing the same issue, when using the advanced fan tuning option in the Intel Graphics Software.
Either way, I´ve contacted Sparkle regarding this issue and I´m currently waiting for an answer on their side.
Did Intel perform any tests or research regarding this weird issue using the Advanced Fan tuning? Have there been any other complaints with this or any other GPU with similar issues?
Miguel Freitas.
PatrickV_Intel
Hi FreitasM545,
Thank you for the update!
I’ll try to replicate the issue on my end as soon as I receive the OEM’s response regarding the GPU fan issue they’ve replaced. In the meantime, could you please share the current graphics driver version installed on your system?
If you have any further questions, feel free to reach out. Thanks again!
Patrick V.
JedG_Intel
Hi FreitasM545,
I'm following up with regards to the  current graphics driver version installed on your system. Kindly share this information at your earliest convenience so we can proceed accordingly.
Jed G.
FreitasM545
Hi Patrick V & Jed G,
I´ve been having this issue since the driver 101.7028. None of the following drivers resolved the issue. I was at 101.8135 but had to rollback due to an export issue in Premiere Pro. I´m now at the WHQL 101.8132.
 I hope this helps identify the issue and for me to understand if this is affecting my GPU and its lifespan/performance in any way.
Miguel Freitas.
JedG_Intel
Hello FreitasM545,
Thank you for sharing this information. To help with our ongoing investigation, we would like for you to try the latest driver version 32.0.101.8135. Please ensure that you perform a clean installation using DDU.
If the issue continuous to persist, kindly generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
JedG_Intel
Hi FreitasM545,
I'm following up to check if you require further assistance. Please let me know so I can proceed accordingly.
Jed G.
JedG_Intel
Hello FreitasM545,
Jed G.
