23095 Discussions
Star Wars Kotor I & II (Intel HD 4000)
Hello everyone,
I recently purchased the Star Wars: Knights of the Old Republic collection. When I try to run the game, the first few intro movies will play then the game crashes with the following error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: swkotor.exe
Application Version: 1.0.3.0
Application Timestamp: 402bc2d9
Fault Module Name: ig7icd32.dll
Fault Module Version: 9.17.10.2867
Fault Module Timestamp: 50635085
Exception Code: c0000005
Exception Offset: 00015881
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 4105
Additional Information 1: a0d9
Additional Information 2: a0d9d28ea7ee2baa08183fd5209c8108
Additional Information 3: c67f
Additional Information 4: c67fda9700fbc540b15604dfb5234d1f
I've installed the most recent drivers with no luck.
My system info is as follows:
Intel(R) HD Graphics 4000
Report Date: 10/28/2012
Report Time[hh:mm:ss]: 00:05:46
Driver Version: 9.17.10.2867
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (Canada)
DirectX* Version: 11.0
Physical Memory: 7627 MB
Minimum Graphics Memory: 512 MB
Maximum Graphics Memory: 1760 MB
Graphics Memory in Use: 76 MB
Processor: Intel64 Family 6 Model 58 Stepping 9
Processor Speed: 3502 MHz
Vendor ID: 8086
Device ID: 0162
Device Revision: 09
Thanks in advance for your help!
DArce
Valued Contributor III
Could you please provide a system report generated by the Intel® Graphics and Media control panel? For information on how to get this report, please check this article:
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
Here's the saved system information from the Information Centre.
Thanks for your time!
Report Date: 10/30/2012
Report Time[hh:mm:ss]: 19:38:39
Graphics Memory in Use: 45 MB
Vendor ID: 8086
Device ID: 0162
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 2124.0
Current Graphics Mode: 1440 by 900
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
* Monitor *
Monitor Name: Generic PnP Monitor
Display Type: Analog
Gamma Value: 2.35
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 16.14 inches
Vertical: 10.24 inches
Monitor Supported Modes:
640 by 480 (67 Hz)
640 by 480 (72 Hz)
640 by 480 (75 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (72 Hz)
800 by 600 (75 Hz)
800 by 600 (56 Hz)
800 by 600 (60 Hz)
832 by 624 (75 Hz)
1024 by 768 (75 Hz)
1024 by 768 (70 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1152 by 870 (75 Hz)
1280 by 1024 (75 Hz)
1280 by 960 (60 Hz)
1280 by 1024 (60 Hz)
1440 by 900 (60 Hz)
1440 by 900 (75 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C 2D 25 02 39 31 41 48
28 10 01 03 0E 29 1A 87 8A D7 A5 A2 59 4A 96 24
14 50 54 BF EF 80 95 00 95 0F 81 80 81 40 71 4F
01 01 01 01 01 01 9A 29 A0 D0 51 84 22 30 50 98
36 00 9A 01 11 00 00 1C 00 00 00 FD 00 38 4B 1E
51 0E 00 0A 20 20 20 20 20 20 00 00 00 FC 00 53
79 6E 63 4D 61 73 74 65 72 0A 20 20 00 00 00 FF
00 48 56 45 4C 41 30 32 30 30 31 0A 20 20 00 B1
* Other names and brands are the property of their respective owners. *
DArce
Could you please try the testing driver posted here?
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21839 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21839
It is an earlier version that you can use for troubleshooting purposes.
Additionally, check the results when you use the driver that is provided by your motherboard manufacturer (either included on a CD/DVD or from their web site).
I tried both drivers (15.28.6.64.2857 and 15.26.6.64.2669, which was included with my motherboard) but I still get the same error message.
Fault Module Version: 9.17.10.2857
Fault Module Timestamp: 50529adc
Locale ID: 4105
Additional Information 1: b3d0
Additional Information 2: b3d0954ef09aeda41cf7326b47f1b8bc
Additional Information 3: d5bb
Additional Information 4: d5bbc0b3173f4c15ce4501fc2e2985b2
Problem signature:
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4f4c8d00
Exception Offset: 0001742e
Locale ID: 4105
DArce
I appreciate your feedback on this matter. I will forward this information to our research team for further investigation on this.
hi, why does your Minimum Graphics Memory is 512MB, i think our system is the same, i installed many drivers, but the Minimum Graphics Memory is still 64MB, can you help me about this? my system info is below:
NICHOLAS_F_Intel
Hello everyone,
Just wanted to inform those of you still playing Star Wars* Kotor I & II that this issue has been fixed with the latest driver release. The driver is version .3071 and can be found at downloadcenter.intel.com
Let me know if you are still experiencing issues after installing this driver!
-Nic
