In fact, it's working well when I watch artiucles or videos submitted by influencers, but it suddenly can't work when I clip a TV series or film on bilibili.com whitch is a website that I surf all the time. It is also strange that the computer is still working and when I take off the HDMI or type C and put it back , the screen can recover. This is the only way that I find to resolve it, but it's so silly. And if I only restart the computer, the screen won't work.
I am looking forward to your advise. The driver is the newest and the diagnostic repaort is as follows:
Report Date: Wednesday, 08 March 2023
Report Time [hh:mm:ss]: 07:59:43 PM
Operating System: Microsoft Windows 11 专业版 10.0.22000
IGCC Version: 1.100.4478.0
Language: zh-Hans-CN
Physical Memory: 15.79 GB
Current Resolution: 2560x1440
Processor: 12th Gen Intel(R) Core(TM) i5-12400
Processor Speed: 2500 MHz
GFX Driver Name: Intel® UHD Graphics 730
Shader Version: 5.1
OpenCL* Version: 3.0
* Microsoft DirectX* *
Runtime Version: 12
Hardware-Supported Version: 12
Vendor ID: 8086
Device ID: 4692
Device Revision: 0C
GFX Driver Version: 31.0.101.4125
Dedicated RAM: 128 MB
Shared RAM: 8 GB
Max Supported Displays: 4
GFX Vulcan: 1.3.237
GFX GOP: 17.0.1073
* Devices connected to the Graphics Accelerator *
Active Displays: 1
Hello 蔡徐坤
Thank you for posting on the Intel️® communities. We understand that you are having issues graphics issues with your system.
- What do you mean exactly by "when I clip a TV series or film on bilibili.com "?
- If possible, share a video showing the error behavior you experience.
- Does the issue persist when using another display or cable?
- We would like to gather more information about your two systems that will help us troubleshoot your issue, so please, provide us with a report using the following programs:
- Intel®️ System Support Utility (Intel®️ SSU):
- Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
- Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save."
- Intel® Graphics Command Center:
- Open the Intel Graphics Command Center
- Navigate to the Support tab
- Select System Diagnostic
- Click Generate Report
- Select Save and name the output file.
Jean O.
Hello 蔡徐坤,
We hope you are doing fine.
Jean O.
Hello 蔡徐坤,
Best regards.
Jean O.
