Intel® graphics drivers and software, compatibility, troubleshooting, performance and optimization
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
16866 Discussions
Things like OpenGL, Vulkan and graphics memory don't appear in intel graphics settings
SKava2
They do not appear to be counted, but when I install the same version or the current version on my installed graphics card, they come back. Then when I restart my computer, they disappear again.
Oscar_A_Intel1
Hello SKava2,
Thank you for posting on the Intel Community.
I understand you're having issues with the Intel® Graphics Command Center and the information displayed, in order to further assist you, please attach the report from the Intel® System Support Utility to check your system environment. You can download it using the link below.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Oscar A.
SKava2
posted a file.
Oscar_A_Intel1
Hello SKava2,
Thank you for providing the report. Please allow us some days to investigate the behavior you're experiencing and I'll be posting back with the outcome.
Oscar A.
Oscar_A_Intel1
Hello SKava2,
Thank you for your time.
I was unable to replicate the issue you’re experiencing. I did see the system information including the APIs (Application Programming Interface) versions and when I restarted the system, they were still there without any issues.
System environment used:
·        Intel® UHD Graphics 630
·        Windows*10 1903
·        Latest graphics driver 26.20.100.6890 (Same as yours)
Download link: https://downloadcenter.intel.com/download/28816/Intel-Graphics-Windows-10-DCH-Drivers?product=98909
I’d recommend you to perform a clean installation of the graphics driver and if you still have the issue, please report it to the Original Equipment Manufacturer to request a customized driver (that might have the fix).
*NOTE: Remember that we recommend using the latest graphics driver provided by the Original Equipment Manufacturer if you encounter any issues using the Intel generic drivers, since they have validated and tested it to properly work on your system.
Hope this helps!
Oscar A.
Oscar_A_Intel1
Hello SKava2,
I'd like to know if you were able to fix the issue by performing the clean installation.
Oscar A.
Alberto_R_Intel
SKava2, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
