21793 Discussions
Treiber nicht signiert für Windows Installation
Marvob
Hallo ntel Community,
wenn ich mein windows 11 neu installieren will, weil es nicht mehr gebootet wird.
Und es neu installieren will, wird die Festplatte(im Setup) nicht gefunden/angezeigt, ich ladete mir den Treiber der Festplatte runter, und will ihn zum setup hinzufügen,
aber wenn ich ihn auswähle, wird eine meldung angezeig, das er nicht signiert ist.
Was muss ich /man wo machen, damit er genommen wird?
Es ist diese Festplatte PCIE RST controlled disk samsung Windows 11 64bit.
Und man bekommt nur eine,exe runter geladen, man nuss aber eine. Inf Datei angeben
Schon im voraus gesagt "Velen Dankfür eure Antwort".
VonM_Intel
Hi, Marvob.
Thank you for posting in our Community.
I would like to clarify the following:
  • When you try to add the driver during Windows 11 setup, what exact message appears stating that it is not signed? If possible, could you please share a picture or image that shows the error?
  • Have you attempted to install the driver despite the signing message, or does it prevent you from proceeding with the installation?
  • Can you confirm where you downloaded the driver for your PCIe RST-controlled Samsung disk?
  • Is the driver you downloaded an executable (EXE) file or do you have access to the INF file separately? If possible, could you please share a link where you downloaded the .exe file? This will help us identify if there's a compatibility issue with your system.
  • Apart from downloading the driver, have you tried any other troubleshooting steps to address the issue of your hard drive not being detected during Windows 11 installation?
Looking forward to your response. Have a nice day!
Von M.
VonM_Intel
Hi, Marvob.
I hope you are doing fine.
Kindly let us know if you still need assistance.
Von M.
VonM_Intel
Hi, Marvob.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
