22965 Discussions
Trouble updating driver for graphic card.
CLono
I'm trying to update the Mobile Intel(R) 945 Express Chipset driver for my laptop, and the newest version is 15.something.something, and I'm currently on version 8.something.something. I've used the automatic driver detection software Intel recommended, and I can download the correct drivers, but when I try to install it, I get an error message saying, "Your computer does not meet the minimum requirements for this update", or something like that. I've made sure that I have the correction version of driver, Windows 7 Ultimate for 64-bit, but it's still not working.
My laptop's bits:
Windows 7 Ultimate 64-bit SP-1.
Intel Core2 CPU T5500 @ 1.66GHZ.
4 GB RAM.
Mobile Intel 945 Express Chipset Family.
Hans_B_Intel
HI Cinerai,
Below is a link that will explain how to install the generic drivers:
Be aware that these are generic drivers with no specific OEM customizations. If your system is a laptop or tablet based system it likely has customizations to the driver made by the manufacturer of the system. If you install the generic driver you will lose the customizations and the system may not work as intended. we recommend you use the latest drivers supplied by the manufacturer.
If you want to try the generic driver I would recommend you set a restore point before updating the driver.
How to Manually Install a Driver in Microsoft Windows 7*
http://www.intel.com/support/graphics/sb/CS-033915.htm http://www.intel.com/support/graphics/sb/CS-033915.htm
Download the zip version of the drive and extract to a folder on your desktop:
https://downloadcenter.intel.com/download/18232/Intel-Graphics-Media-Accelerator-Driver-for-Windows-7-64-zip- https://downloadcenter.intel.com/download/18232/Intel-Graphics-Media-Accelerator-Driver-for-Windows-7-64-zip-
CLono
So, I downloaded and extracted the driver update, and uninstalled the current driver for my Intel chipset. I restarted my computer and then installed the update and allowed my computer to restart again. However, it's still at the version that it was at before. I'm not sure why it's not updating to version 15, but I copied the dxdiag file, if that helps with anything.
Display Devices
Card name: Mobile Intel(R) 945 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) GMA 950
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_27A2&SUBSYS_206217AA&REV_03
Display Memory: 256 MB
Dedicated Memory: 0 MB
Shared Memory: 256 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO1344
Native Mode: 1280 x 800(p) (60.002Hz)
Output Type: Internal
Driver Name: igdumd64.dll
Driver File Version: 8.14.0010.1930 (English)
Driver Version: 8.15.10.1930
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 9/23/2009 14:22:56, 5472256 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-64E2-11CF-9073-6800A2C2C535}
Vendor ID: 0x8086
Device ID: 0x27A2
SubSys ID: 0x206217AA
Revision ID: 0x0003
Driver Strong Name: oem1.inf:Intel.Mfg.NTamd64:i945GM0:8.15.10.1930:pci\ven_8086&dev_27a2
Rank Of Driver: 00F42001
Hans_B_Intel
Hi Cinerai,
Just to clarify, did you use the procedure on how to manually install a driver in Microsoft Windows 7*?
If so, then it is likely that your machine will not allow the installation of a generic driver, this would be an exception made by the OEM to the VBIOS. You would need to contact the manufacturer to verify whether or not your driver can be updated with a generic one.
