22231 Discussions
UHD 630, 5120x1440 not listed as supported mode via USB-C
zachpn
Hi.
I am trying to get my new Monitor running properly on my laptop.
Monitor Samsung G9 Neo LS49AG95 (5120x1440 native)
PC: Dell latitude 5591 with intel  i7- 8850H; UHD 630 and Nvidia MX130
Latest UHD630 driver is installed: 31.0.101.2111
Cable used: 4k HDMI to USB-C Cable
Max supported resolution: 3840 x 1080 (60p Hz, 4K)
I tried the Dell 5k enable .reg patch, reinstalled monitor drivers, updated UHD Drivers, tried to add the resolution with intel gfx control software, and tried to add the resolution with GRU. Nothing worked.
Report is attached.
Any help is appreciated.
Steven_Intel
Hello zachpn,
Please provide the following information:
According to the manual provided by Dell, the maximum resolution for HDMI 2.0 is
4096x2160 at 60 Hz, page 14 (https://dl.dell.com/topicspdf/latitude-15-5591-laptop_specifications2_en-us.pdf). As well, please check the processor graphics specifications here https://ark.intel.com/content/www/us/en/ark/products/134899/intel-core-i78850h-processor-9m-cache-up-to-4-30-ghz.html
Steven G.
zachpn
- As the Laptop does not have a DP connection but only HDMI 1.2, and because the DP port on my Monitor is already occupied, the HDMI to USB-C cable is as straight as I can go.
- I did not use any Beta drivers, no
- On this Laptop? No. Its a new Monitor.
The issue was the Cable I used. I could not deliver the required bandwith. When I added 5120x1440@30Hz with GRU, the option was also displayed in the display settings.
Bought a new 8K@30Hz HDMI cable and now 5120x1440 @60Hz is working.
Steven_Intel
Thank you for your response.
I am glad to know you are now able to set the desired resolution. Thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior.
Since the thread is now solved, we will proceed to close it.
Steven G.
