Hi! I has CPU Intel i5-9600k that has UHD 630 graphic processor. It work on motherboard ASRock Z390 Pro4. I bought new monitor with resolution 2560x1440 that supports 144Hz. UHD 630 can work with resolution 4096x2304 on 60hz. The HDMI on my motherboard has version 1.4. This version HDMI can work on resolution 2560x1440 with 75hz. Why Intel's graphic driver don't give me select variant 2560x1440@75hz? Why maximum frequency that I can select is 60hz? UHD 630 can operate at a resolution of 4096 x 2160 @ 60 Hz, which is significantly more in terms of bandwidth of my desired 2560x1440 @ 75hz
Hello All,
As per user request, we will proceed to close this thread.
Andrew G.
A Contingent Worker at Intel
