23077 Discussions
UHD630 i5 8300h, New DCH driver makes maximum resolution 1024x768
Krml
Hi all,
I have a MSI Laptop with i5 8300h and UHD630. The problem is when I try to install new DCH drivers, my maximum resolution becomes 1024x768 instead of 1920x1080. I also noticed that i5 8300h does not belong to supported processors of new drivers. So maybe that's why.
If I use old legacy driver 100.6373, the display color output is limited to 6-bit instead of 8-bit. It was a known bug but fixed with DCH drivers. Unfortunetly, when I install these drivers my screen resolution is limited to 1024x768 as I said.
Can you guys publish a driver which fixes 6-bit error and can be installed on i5 8300h cpus? Thanks.
VARADHARAJAN
Valued Contributor II
in new dch drivers also gives 6bit only, but microsoft basic driver gives 8bit .
Whats the hardware device ID of intel UHD .
I am using latest DCH 25.20.100.6471 on asus laptop it gives FHD 1920x1080
