23081 Discussions
Unable to update Intel HD 4000 driver to 15.33.30.64.3958
DPage4
Hi i recently downgraded to "windows 7 Home Premium 64-bit", I have an Acer E1-571 and have had a lot of issues with driver's.
As I am sure some of you other Acer users there driver support is awful and i had to download drivers from else where. I have noticed an issue tho, for some reason i cannot install the driver version "15.33.30.64.3958" it says it installs but when I check driver version it is "10.18.10.4061", although this driver version is not the worse i still really need to upgrade to 15.33.30.64" as its more stable and will provide better performance.
I hope someone is able to help em as is a very annoying problem
Many Thanks
Dexter
Jose_H_Intel1
Hi Dexter, you are actually trying to downgrade from "4061" to "3958".
You may want to take a look into the release dates for the driver versions and if you still need to use "3958" I recommend you uninstalling the version your computer is currently using.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3712 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3712
http://www.intel.com/support/graphics/sb/CS-020667.htm Graphics Drivers — Understanding The Intel® Graphics Driver Version Number
http://www.intel.com/support/graphics/sb/CS-011363.htm Graphics Drivers — Identifying Your Graphics Driver Version
DPage4
Was meant to be latest version what I meant to say is I can't update to 15.33.32.4061
Jose_H_Intel1
You may want to try the manual driver installation:
  1. http://www.intel.com/support/graphics/sb/cs-030348.htm Download the graphics driver ZIP file.
  2. Unzip the file to a designated location or folder.
  3. Click Start.
  4. Right-click Computer > Manage. When prompted for permission from User Account Control, click Yes.
  5. Select Device Manager from the navigation tab on the left.
  6. Double-click Display Adapters.
  7. Right-click the Intel® Graphics Controller and click Update Driver Software.
  8. Click Browse my computer for driver software.
  9. Click Browse and select the directory where the driver files are located.
  10. Click Next. Drivers are now being installed.
  11. Reboot computer when prompted.
http://www.intel.com/support/graphics/sb/CS-033915.htm Graphics Drivers — How to Manually Install a Driver in Microsoft Windows 7*
