22860 Discussions
Unable to update chipset and graphics
DJone16
Hi, I recently installed the new version of Intel Driver Update Utility and I had 3 updates showing up at one point (1 as of now.. doesn't recognize my graphics card). The first being Intel Chipset Driver Software 10.1.1.14. I am unable to update this as it fails everytime... no error just "failed". My biggest problem is trying to update the graphics driver. I have tried numerous versions of the Windows 10 4th Gen drivers but I get either "Operating system not supported" or "computer does not meet specs". One of the versions I am trying to install is 15.40.18.64.4380. Here are some of my specs. Thanks in advance!
Operating System: Windows 10 Pro 64-bit (10.0, Build 10586) (10586.th2_release_sec.160223-1728)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP ENVY 17 Notebook PC
BIOS: F.65
Processor: Intel(R) Core(TM) i7-4702MQ CPU @ 2.20GHz (8 CPUs), ~2.2GHz
Memory: 16384MB RAM
Available OS Memory: 16316MB RAM
Page File: 3551MB used, 15196MB available
Windows Dir: C:\WINDOWS
DirectX Version: 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
DxDiag Version: 10.00.10586.0000 64bit Unicode
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0416&SUBSYS_1968103C&REV_06
Display Memory: 8270 MB
Dedicated Memory: 112 MB
Shared Memory: 8158 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: AUO219D
Native Mode: 1920 x 1080(p) (60.037Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32
Driver File Version: 10.18.0015.4248 (English)
Driver Version: 10.18.15.4248
DDI Version: 12
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 2.0
Graphics Preemption: Primitive
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Hello, @d_jones06:
Please try installing the driver manually, see here for the instructions http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html How to Manually Install an Intel® Graphics Driver in Windows® 10 &... and here for the download https://downloadcenter.intel.com/download/25860/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]. For the Intel® Chipset Device Software make sure to follow the instructions stated here https://downloadmirror.intel.com/20775/eng/readme.txt https://downloadmirror.intel.com/20775/eng/readme.txt.
Amy.
DJone16
Okay so I verified my version of the Chipset Software in the registry and it looks like I have the newest version it's just that I keep getting the update in the Intel Utility. The Graphics Driver [15.40] doesn't have a .zip download option so I cant install the driver manually. Also I have tried to install previous versions this way without any luck.
Please try with this version https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen] and the method attached.
Amy.
DJone16
Thanks Amy, worked perfectly!
Sure, you're welcome.
If you need further assistance let us know.
Amy.
