Hi , I am unable to update my graphic card using this link: https://downloadcenter.intel.com/download/25588/Intel-Graphics-Driver-for-Windows-7-8-1-15-36- Download Intel® Graphics Driver for Windows 7/8.1* [15.36] for the drive highlighted below.
When i try to run the setup from the ZIP folder downloaded, this message popped out.
Specification for my laptop:
Driver Version: 20.19.15.4380
Operating System: Windows* 10 Pro (10.0.10586)
Default Language: English (Singapore)
Physical Memory: 8076 MB
Vendor ID: 8086
Device ID: 0416
Device Revision: 06
Video BIOS: 2179.0
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i7-4710MQ CPU @ 2.50GHz
Processor Speed: 2494 MHz
Processor Graphics in Use: Intel(R) HD Graphics 4600
Shader Version: 5.0
OpenGL* Version: 4.3
OpenCL* Version: 1.2
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 13.78 inches
Vertical Size: 7.48 inches
Supported Modes
1920 x 1080 (60p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 7E 03 00 00 00 00
00 15 01 03 80 23 13 78 0A 25 B5 A1 59 59 9D 27
1C 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 34 3A 80 20 71 38 2C 40 30 48
35 00 59 C2 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 35 36 57 46 34 2D 53 4C 42 35 00 30
Any ideas on what is going on with this issue are greatly appreciated.
Thanks!
Based on the graphics report, I noticed that you are currently running the latest graphics driver available for your graphics controller.
This would be version 4380, there is no need to get an updated one for now.
Allan.
Allan.
