23102 Discussions
Update Drivers for Intel® Core™ i5-4460 CPU @ 3.20GHz
RGauc
I very often get crashes with BSOD, on Windows 10, 64 bit so I am updating my drivers...
I have the Intel64 Family 6 Model 60 Stepping 3
Processor currently has driver version 10.0.17134.1
However on the web site I see that there is a significantly better version 15.40.38.4963
When I try install I receive the message: The computer does not meet the minimum requirements for installing the software.
Driver and Support Assistant says that there are no software updates available.
Is it perhaps because I don't have OpenGL/OpenCL?
is it normal? Any help or advice to see if I can update would be appreciated.
Robert
AlHill
This is your processor.
https://ark.intel.com/products/80817/Intel-Core-i5-4460-Processor-6M-Cache-up-to-3_40-GHz Intel® Core™ i5-4460 Processor (6M Cache, up to 3.40 GHz) Product Specifications
Click on "downloads and software" and you will find your drivers.
OpenGL and OpenCL are included in the graphics driver.
BSODs have an error code associated with them. Provide the code.
Also, provide the anti-virus software you are using.
And, are you using a laptop or desktop? Provide the complete system model number.
Last, have you used the drivers provided by your system manufacturer? If not, you should try those first.
If you have trouble finding this information, run the utility below and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility for Windows*
Doc
RGauc
Hi
Thanks for your response.
I can confirm that according to Intel site I should be able to install the drivers.
All manufacturer drivers except intel are up to date.
I have attached the specs.
I am using Kaspersky Free as antivirus.
The BSOD error codes are quite varied to be honest.
Thanks a lot
Robert
AlHill
You have an nvidia graphics card. Typically, when you have an add-on card, it will disable the cpu graphics.
You can confirm this in the bios. If it is as I say, then you should not be updating the cpu graphics.
Also, with many and varied bsods as you say, I would start looking at memory issues.
Lastly, I would certainly look at getting rid of kaspersky for something better.
Doc
RGauc
Thank you very much Al for the advice.
Robert
Hello robertgauci,
I am following up with your case and see that we have not heard back from you.
Were you able to solve your problem?
If you need more assistance do not hesitate to reply.
David V
VARADHARAJAN
Valued Contributor II
I am also using asus laptop , evnethough I got same error message like
"The computer does not meet the minimum requirements for installing the software"
but I solved graphics problems by installed manually , now my laptop has 24.20.100.6136 driver
