23854 Discussions
Using scale_qsv to change pixel format
asheimo
I am trying to transcode a video in ffmpeg and use a complete hardware pipeline and also convert the video for 8bit to 10bit. It seems that scale_qsv should be able to do this using the format option but I have yet to be able to successfully do this. I am looking for guidance as to how to move forward.
when using -vf scale_qsv-format-p010le ffmpeg errors with the following message:
[Parsed_scale_qsv_0 @ 000001beba542980] Error synchronizing the operation: -21kbits/s speed=N/A
Error while filtering: Unknown error occurred
Failed to inject frame into filter network: Unknown error occurred
Error while processing the decoded data for stream #0:0
Sebastian_M_Intel
Hello asheimo,
Thank you for posting on the Intel® communities.
  • Are you designing a type of software/hardware?
  • Also, what is the Intel® product that you are working with?
This information can help us to guide you to the correct support place.
Sebastian M
Intel Customer Support Technician
asheimo
I am currently using an i7-10700k but really this question applies to qsv in general, I want to be able to create a full hardware pipeline via ffmpeg and convert an 8bit input to a 10bit output.
Sebastian_M_Intel
Hello asheimo,
Thanks for the update.
Please let me review this information internally, and kindly wait for an update.
Once we have more information to share we will post it on this thread.
Sebastian M
Sebastian_M_Intel
Hello asheimo,
Thank you for patiently waiting.
After double-checking internally, we understand that you are looking to transcode a video using QuickSync, mainly the function "scale_qsv", however; access to the hardware encoder is provided through the FFmpeg application. Since you have usability questions, they need to be addressed by the app developer or even perhaps their own community: https://lists.ffmpeg.org/mailman/listinfo/ffmpeg-user/
We can only confirm the hardware encoder is there as you can check here under Processor Graphics, Intel® Quick Sync Video: https://ark.intel.com/content/www/us/en/ark/products/199335/intel-core-i7-10700k-processor-16m-cache-up-to-5-10-ghz.html
You will need to check with the FFmpeg app support for more help.
Sebastian M
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
asheimo
Let me ask the question differently. Is QuickSync capable of converting an 8bit input to a 10bit output or can that not be done completely in hardware?
Sebastian_M_Intel
Hello asheimo,
Thank you for your reply.
Please let me confirm this internally as well. Once we have an update we will share it here also.
Please kindly wait for a response.
Sebastian M
Sebastian_M_Intel
Hello asheimo,
I would like to let you know that the answer to your previous question is yes, you can use Quick Sync to convert from 8bit to 10bit video for HEVC as long as the application is optimized for Quick Sync. We tested it recently with Handbrake version 1.3.3.
Sebastian M
Sebastian_M_Intel
Hello asheimo,
Were you able to check the previous post and see our outcome? Please let me know if you need more assistance.
Sebastian M
asheimo
It is frustrating that after telling me to ask over at ffmpeg for help you tell me that handbrake works fine so you were willing to test handbrake but not ffmpeg. Regardless, can you point me towards any instruction about how to do the conversion. Is scale_qsv the proper way to do so? Should I be able to just specify the pixel format in the output and qsv does the rest?
asheimo
Further digging into your answer that handbrake supports this functionality is false, per the documentation; HandBrake Documentation — Intel QuickSync Video
Only video encoding is performed by the hardware encoder. Every stage prior to and after video encoding including decoding, filters, audio/video sync, audio encoding, muxing, etc., is performed by the CPU.
My request was asking about a complete hardware pipeline for decoding and encoding and doing the conversion from 8 to 10 bit in the process.
Sebastian_M_Intel
Hello asheimo,
Thanks for your reply.
Please allow me to check this with the team in charge of this testing one more time and kindly wait for a response.
Sebastian M
Sebastian_M_Intel
Hello asheimo,
Internally we are looking into this, however, we would like to confirm some information:
  • Could you share the file and detailed command(s) you are using with us?
  • Also, we would like to better understand the context of why you are pushing to convert 8 to 10 bits, since it will occupy your space and not give you any quality benefit
Sebastian M
asheimo
You are incorrect about the quality benefit, converting from 8bit to 10bit reduces if not resolves in most cases color banding associated with transcoding. This alone makes the conversion worth it.
any 8bit file can be used. command is as follows:
ffmpeg -loglevel error -stats -hwaccel qsv -qsv_device 1 -c:v vc1_qsv -i <path to mkv input> -map 0:0 -c:v h264_qsv -pix_fmt:v p010le -b:v 6000k -look_ahead:v 1 -color_primaries:v bt709 -color_trc:v bt709 -colorspace:v bt709 -metadata:s:v title= -disposition:v default -map 0:1 -c:a:0 copy -metadata:s:a:0 title= -disposition:a:0 default -sn -metadata:g title= -default_mode passthrough <path to mkv output>
which results in the following error message.
Impossible to convert between the formats supported by the filter 'Parsed_null_0' and the filter 'auto_scaler_0'
Error reinitializing filters!
Failed to inject frame into filter network: Function not implemented
Sebastian_M_Intel
Hello asheimo,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
Sebastian_M_Intel
Hello asheimo,
Thanks for the information.
Kindly wait while we review this inquiry.
Sebastian M
Sebastian_M_Intel
Hello asheimo,
Thank you for your patience.
We would like you to try the command below:
ffmpeg -v verbose -stats -hwaccel qsv -qsv_device /dev/dri/renderD128 -c:v h264_qsv -i ./AUD_MW_E.264 -map 0:0 -vf 'vpp_qsv=w=1920:h=1080,format=yuv420p10le' -c:v hevc_qsv -b:v 6000k -look_ahead:v 1 -color_primaries:v bt709 -color_trc:v bt709 -colorspace:v bt709 -metadata:s:v title= -disposition:v default test.mkv
Sebastian M
Sebastian_M_Intel
Hello asheimo,
Were you able to test the previously recommended command? Please let me know if you need more assistance.
Sebastian M
asheimo
The linked clip is missing could you please send it again.
asheimo
This is the output  received, it is failing
[h264_qsv @ 000001eb8cdb7040] Error initializing the MFX video decoder: invalid video parameters (-15)
Error while decoding stream #0:0: Invalid argument
[h264_qsv @ 000001eb8cdb7040] Decoder: output is video memory surface
[h264_qsv @ 000001eb8cdb7040] Error initializing the MFX video decoder: unsupported (-3)
Error while decoding stream #0:0: Function not implemented
Sebastian_M_Intel
Hello asheimo,
Please find the test clip attached.
Can you please check it and let us know?
Sebastian M
