22884 Discussions
W8.1 / Intel HD Graphics got VIDEO_DXGKRNL_FATAL_ERROR problem
RFoX3
Hello, guys.
I've got a big problem with my laptop, recently I cleaned up my programs and files, and also I've installed again the O.S.
After the O.S. installation complete, there I go add the drivers..
Everything works fine till install the 'onboard graphic driver', after this -> Blue screen of Win presenting something like 'VIDEO_DXGKRNL_FATAL_ERROR'.
Then I've tried lots of 'fixes', updated the DirectX and the drivers, looked in forums and nothing..
If I enter in safe mode and remove the driver, it works apparently good, but the graphics it's kind a little blur.
Specifications:
notebook -> Avell titanium b154 se plus
Processor -> Intel i5 4200M
Memmory -> 8Gb
Onboard graphics -> Intel HD Graphics
'offboard' graphics -> Geforce 750M
OS -> Microsoft Windows 8.1 Pro x64
Sorry my bad english.
I hope someone could help me.
R.
ROBERT_U_Intel
Hi Ray
Try this.
Run Windows Update and install updates, reboot, run Windows Update again and repeat until there are not more updates to install. This should install all the necessary drivers for your system. Post back to this thread with your result.
Robert
RFoX3
Hello, Robert.
Thanks for the answer.
I tried what you said, but still the same problem.
I've got a Windows 7 x64 DVD with a friend, install and again ~blue screen~ now shows the message "driver power ...(failture or something)".
I hope someone has a solution
I'm getting worried about this...
R.
BKlem
Hello, RayTheFox,
I've been experiencing the very same problem on my HP EliteBook 840 G1 notebook. It all started when I've been using Win 7 x64 and the tech support had no answer for it. It continued after I upgraded to Win 8.1.
I did manage to solve it by using a fix on this page https://support2.microsoft.com/kb/2990029/en-us https://support2.microsoft.com/kb/2990029/en-us
I suggest you follow the procedure as explained in the "Workaround" section.
Please, let me know if it helped you, too.
Bostjan
