23108 Discussions
What is the best shared memory for intel hd 4000?
rtion
because mine is 1.7gb.. my Ram is 4gb, intel i3. 1.8ghz processor
Amy_C_Intel
Hello rhenzkie05,
In most cases, the computer manufacturer has already configured the system to use the maximum amount of graphics memory that is possible for your particular computer model. The maximum share memory for Intel® HD graphics 4000 is 1.7GB. Sometimes you can change these values through BIOS level.
Check with your computer manufacturer if there are tips on increasing the amount of graphics memory for your computer model.
If you are interested in additional information see graphics memory frequently asked questions:
http://www.intel.com/support/graphics/sb/CS-029090.htm http://www.intel.com/support/graphics/sb/CS-029090.htm
Amy.
rtion
Hello Amy,
Thanks for your response
My other question is my hd 4000 only have 32mb dedicated memory but the others have a 64mb dedicated memory..
Amy_C_Intel
In this case the shared memory capacity is a feature set by the computer manufacturer in the Video BIOS, as I mention sometimes you can change these parameters through BIOS level, if there are no options available in the BIOS then there are no options to change the parameters.
Amy.
