19869 Discussions
Where does the display settings are saved in windows 10?
Jackpotasd
I am trying to set a default value of scaling remotely on a set of machines, with Windows 7 Intel HD Graphics driver set the scaling as Full Screen by default, meanwhile in Windows 10 I am seeing that by default the scaling is set to Maintain Aspect Ratio.
Windows 7 Driver Version: 21.20.16.4574
Windows 10 Driver Version: 27.20.100.9171
Any idea where I can find these settings so I can replace them in many machines remotely?
AndrewG_Intel
Hello @Jackpotasd
In order to understand better the scenario and request, could you please provide more details?
1- How many machines are you trying to configure this way?
2- Why are you trying to "set a default value of scaling remotely"? What is the purpose/goal of this configuration that you are interested in?
3- Just to make sure, are you trying to set this for both Windows* 7 and Windows* 10? Also, could you please confirm the models of the Processors/Graphics model(s)?
Andrew G.
Jackpotasd
Hi Andrew,
     More than 100, I am installing an application on top of Win10 that is executed full screen.
     I want to use the whole screen of the device, right now on Win10 scaling is set to Maintain Aspect Ratio and I want to set Full Screen     Scaling in a script to I can apply these settings to a bunch of machines at the same time.
     I am just trying to get this done on Win 10, I am adding as example Win 7 in which Full Screen Scaling is coming apparently by default, while in Win 10 default value is Maintain Aspect Ratio.
Intel HD Graphics 530
Maybe there are some registry values that I can manipulate, or some profile related approach, maybe a PS script or something.
Regards.
AndrewG_Intel
Hello Jackpotasd
Thank you for your response.
We will review this further and post back in the thread as soon as more information is available.
Andrew G.
AndrewG_Intel
Hello Jackpotasd
We do apologize for the delay in getting back to you.
Regarding your inquiries on how to set Full Screen Scaling in a script (e.g.: by manipulating "registry values") or where to locate the display settings, our recommendation is to contact your Original Equipment Manufacturer (OEM) for assistance to request customization in the tool's default behavior. This is because your OEM is the best channel of support for this type of request. Thank you for your understanding.
Andrew G.
AndrewG_Intel
Hello Jackpotasd
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
