22896 Discussions
Which driver should I download, my minecraft win10 version prompts that my graphics driver is t
mazong
Intel® HD Graphics
  • Driver Details
  • ProviderIntel Corporation
  • Version8.15.10.2900
  • Date11/26/2012
  • Device Details
  • Adapter CompatibilityIntel Corporation
  • Video ProcessorIntel® HD Graphics (Core i3)
  • Resolution1440 x 900
  • Bits Per Pixel32
  • Number of Colors4294967296
  • Refresh Rate - Current75 Hz
  • Refresh Rate - Maximum75 Hz
  • Refresh Rate - Minimum59 Hz
  • Adapter DAC TypeInternal
  • Adapter RAM1.72 GB
  • AvailabilityRunning at full power
  • StatusThis device is working properly.
  • LocationPCI bus 0, device 2, function 0
  • Device IdPCI\VEN_8086&DEV_0042&SUBSYS_D0001458&REV_12\3&13C0B0C5&1&10
    I don’t know which driver to download, and it shows that the device does not meet the minimum requirements for installation.
    My Intel® Driver & Support Assistant does not detect that I have a new driver update
    Can you give me a download address.
AlHill
It is very likely that there is no Intel driver for your graphics for Windows 10.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
mazong
AlHill
You are using the Microsoft generic graphics driver, which LACKS features and performance.
There is no Intel supplied driver for Windows 10.
mazong
I tried many methods, such as Win10 driver check update,But i still can't solve,So how do I solve it, the display driver is too old and I can’t use many applications.
AlHill
There is no driver that will help you.  And, any driver site that says they can help you are not telling you the truth.
If your machine is a desktop, you might be able to find an older nvidia card, like a gtx 750 or 1060.
Otherwise, it is time to dispose of that old hardware for something new(er).
