22468 Discussions
Why does Intel not support 10 bit display in SDR?
heihei
The same laptop screen (this screen supports 10bit output, but does not support HDR and WCG), which supports 10bit SDR output in AMD core, but only 8bit SDR output in Intel Core. Can we solve this problem? The comparison products are Lenovo's mega 14s Intel version and AMD version.
David_G_Intel
Hello heihei
Thank you for posting on the Intel️® communities. To provide any recommendation we need more information from the system, please share with us the following:
  •  Intel® System Support Utility (Intel® SSU)
    • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
    • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
    • Click on the menu where it says "Summary" to change to "Detailed View".
    • To save your scan, click on "Next", then "Save".
  • Intel® Graphics Command Center report
    • "Support" > "System Diagnostic" > "Generate Report
David G
Intel Customer Support Technician
David_G_Intel
David G.
David_G_Intel
David G.
