Intel® graphics drivers and software, compatibility, troubleshooting, performance and optimization
18281 Discussions
Why does the Intel Driver & Support Assistant tell that is necesary that update "Gráficos Intel®: Controladores DCH® 10 de Windows" and when I want to install tell me that I dont have the minimum requieres componente? Thanks you all!
BGuad
AlHill
Describe your hardware and Os:
What is your processor model number?
What is your device model number? Laptop or desktop?
What OS? Windows 10? What version? 1903?
Doc
BGuad
I have Windows 10 1903 and the processor ir i9-9900K, it is a desktop I made buying differents components, the motherboard is Msi z390 pro carbon ac.
I dont know why the Intel Driver & Support Assistant told me that is necesary to update and then it fails because i dont have minimun requires! thank you!Captura.PNG
AlHill
You did not answer all the questions. What version of WIndows 10 are you using? 1903?
Doc
BGuad
Yes! I writed it, I am using Windows 10 1903 but I think this error was in the last update of windows too!
AlHill
Are you using an add-on graphics card as well?
Doc
BGuad
If you are talking about an external GPU no, Im not using an external, I have the Nvidia rtx 2070!
AlHill
I am talking about an add-on card (like the nvidia), and not an eGPU.
On many motherboards, using an add-on card will disable the onboard (intel) graphics.
You need to check your bios settings, or contact MSI for support with their bios and video settings.
Doc
BGuad
You were right!! I change my bios setting and I initiate windows with de Intel Integrate Graphics and it works! The Intel Driver & Support Assistant change the update description and now it update sucssesfull!
Thank you!!
AlHill
Glad to help.
Doc
