22940 Discussions
Will my graphics card run ultra wide screen
MJH1
Hi, I want to upgrade to ultra wide screen with 2560x1980 re.  Will my system run this?  I have downloaded the system support file which is attached.
Jean_Intel
Hello MJH1,
Regarding your question, the Intel® HD Graphics 500 supports up to 3840x2160@30Hz when using HDMI cable; or 4096x2160@60Hz when you use DP cable, which indicates that the system will be capable of running at 2560x1980 resolution. However, you must know that Original Equipment Manufacturer (OEM) limitations may affect the performance of your system, and it may not reach these resolutions.
Jean O.
Jean_Intel
Hello MJH1,
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
