I get the following error message when I try to look at the driver. This is on a NUC5i5,,,
The driver for this device has been blocked from starting because it is known to have problems with Windows. Contact the hardware vendor for a new driver. (Code 48)
The generic Windows driver works but is slow.
- Tags:
- driver blocked
Windows 10 insider builds are not supported.
You can TRY the drivers here:
https://downloadcenter.intel.com/download/29971/Intel-Graphics-Driver-for-Windows-15-40-
Perhaps the "manual" instalation method will work.
Thanks for your suggestion. I was using the driver suggested
by the Intel Driver and Support Assistant.
Apparently the problem is related to the use of the Intel Driver
with VM and Hypervisor features. When I turned these features
off, the Intel Driver was accepted.
Since I do not have to use VM or Hyperviser on my NUC system,
This is an acceptable solution. Perhaps the next version of the
driver will be more amenable to virtualization per Microsoft.
