23077 Discussions
Windows 10 Insider build 14279 vs. igfxCPL
Stefan3D
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
.NET exception when selecting display or 3d, blank window with options or energy in igfxCPL
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
100% with this build,
worked with previous builds, don't remember when i used CPL last time
Hardware (HW)
Brand and Model of the system.
ACER Aspire E5-571G
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Optimus
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP
How much memory [RAM] in the system (see note2 below).
8 GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
N/A
Hardware Stepping (see note1 below).
<p style="margin-bottom: 0.0001p...
IUman
Hello Stefan3D,
Thank you for joining the Intel communities.
You can get better support at https://software.intel.com/en-us/ https://software.intel.com/en-us/
Ivan
Stefan3D
@ ivanu_intel
Looks like Microsoft was the culprit.
Things got worse in build 14291, they nuked their own VS 2015 with a similar exception.
I guess that draw their attention.
Windows build 14295 is working again with igfxCPL.
IUman
Thank you Stefan3D for sharing that information on this thread and I'm glad that your issue has been resolved.
Best wishes,
Ivan
