22939 Discussions
Windows 8.1 HDMI Video not working
AStev6
Hardware: Dell Inspiron 17R
OS: Windows 8.1 x64
-connecting to-
LG 32LS3400
Issue:
Couple weeks back (as of 1 November 2014) I was in class doing a render with Cinema 4D, a 3D animation software. The render itself was extremely demanding of PC resources and froze. I tried to abort the render, and got a window I do not recall except I did briefly see "Display." Same night I got home I hooked up my laptop to the LG TV and noticed glitches on the TV, flashing, all until I dropped the refresh rate from 60 hz to 30 hz. I had tried connecting to other TV's and had no issue. As for the LG, It still had minor glitches but the screen stayed on and I continued to figure out what went wrong. Several days ago, I read in a post to delete the display driver and reinstall it.
Soooooooooooooooooooooooooooooooooooooooooooooooo I did just that.
NOW, I get no picture on either my LG or other TV's. Or any monitor.
My laptop does recognize the fact there is a TV. Using Debut Video Capture, the preview shows my main desktop plus the extended desktop.
So now I've basically ran out of ideas, and the last thing I want to do is completely nuke my laptop and rebuild it for an extended display.
Anyone know a good fix?
Thanks!
-Alex
Silvia_L_Intel1
Alex, do you have video on your laptop?
Can you try doing a BIOS update?
What I would like to try is to install the original Graphics driver provided by Dell?
http://www.dell.com/support/home/us/en/19/product-support/product/inspiron-17r-5721/drivers http://www.dell.com/support/home/us/en/19/product-support/product/inspiron-17r-5721/drivers
You may also want to try to check if there is a firmware update for your monitor.
If you are able to access Windows, you may check if you can restore your computer to the last working state by choosing "System Restore".
AStev6
I did do a BIOS update, as well as installing a graphics driver provided by Dell. I also completely refreshed my PC. Still not getting a connection.
Silvia_L_Intel1
Alex, can you attach copy of your latest dxdiag reports please? (Start -> Run -> dxdiag -> Save All Information).
Could you also provide me the model number and the type of the cable you are using?
AStev6
As for the HDMI cable, I don't know. The first one I had was from Amazon.
AStev6
That's the one I've used. It still doesn't work.
Silvia_L_Intel1
Alex, would you please try the following:
  • Remove or uninstall all Intel Graphics drivers
  • Reboot your system
  • Try to do a dual display. (This may or may not work, it is going to depends on your system) I just want to know if this behavior is being cause by the driver or something else.
You can also try to install our previous Graphics driver and try to connect the 2nd display https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24392 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24392
Or try the latest version available on our site https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24329&lang=eng&ProdId=3712 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24329&lang=eng&ProdId=3712
Since our drivers are generic drivers you may need to force the installation by performing manual procedure
See here for instructions: http://support.intel.com/support/graphics/sb/CS-022355.htm Graphics Drivers — Computer manufacturer graphics driver detected
AStev6
After disabling Wifi, I uninstalled the graphics driver, which got replaced by the basic graphics driver. I rebooted, and tried to connect my second screen, which didn't work. I enabled my wifi and I manually installed the graphics driver you had provided. At first I got a notification saying that the driver was already installed, and then my Intel HD Graphics 4000 came back. Although there is minor difference. My TV, instead of saying "No Signal" when you first switch to the HDMI port, now displays "Connecting." But still shows no picture and shoots around the "No Signal" box.
Silvia_L_Intel1
Alex, I suggest you contacting Dell since we already perform all recommended troubleshooting.
The last think you could do is use another HDMI cable, there is a high possibility that the cable you are using is not working as expected.
AStev6
Bought a brand new one. Nope. I HIGHLY doubt the cable is the issue.
Silvia_L_Intel1
Alex, please get in touch with Dell, this does not seems to be a driver issue since you already tried some of them.
This could be a problem with the HDMI port on your laptop.
AStev6
I did contact Dell. They had me run a diagnostic which told me that it was for sure software related. Then they wanted me to pay 150 bucks to fix it, which I politely said no to.
AStev6
I did just take a look at something, is it normal for the "System Video Memory" to be at 0 mb?
Silvia_L_Intel1
Alex, this is not normal but we have seen other system manufacturers that showing the correct system memory information.
Please check the picture below from my Lenovo laptop. It also shows 0 MB system video memory, but I do have dual display using a "display port".
AStev6
My graphics card displays the exact same numbers as yours, even with the monitor connected to my laptop.
Silvia_L_Intel1
Alex, I will be necessary for you to get assistance with Dell. You may want to try Dell's community http://en.community.dell.com/ http://en.community.dell.com/
