Community
cancel
Showing results for
Search instead for
Did you mean:
Windows Vulkan driver advertises sampleRateShading but it has no effect
Creating pipelines with VkPipelineMultisampleStateCreateInfo::sampleShadingEnable set to VK_TRUE and VkPipelineMultisampleStateCreateInfo::minSampleShading set to 1.0f should shade every sample independently resulting in supersampling.
This does not work. The result is identical to multisampling,
We are investigating your issue, I will update you when we learn more.
Hi Axel,
We have a fixed for both the 15.46 and 15.45 drivers. The next 15.26 driver release (later this month) should have the fix.
-Michael
Hi Axel,
Quick update, we are still looking in this issue. Hope to have a fix soon, but I don't have an exact ETA for you right now.
-Michael
Hi Axel,
We have a fix for you your issue, the driver with the fix will be released end of September.
-Michael
Is there a patch?
The fix for this issue is currently available in driver which was posted today. Thank you for your patience.
https://downloadcenter.intel.com/download/27199
