18929 Discussions
Wrong display numbers
HardwareProvis
I'm having trouble with a signer model Topaz TD-LBK101, the issue comes due to Intel graphic command centre's display numbers not matching Windows´ display numbers. This causes some of the behaviour of the signer to happen on the signer itself and some in the principal monitor.
Completly uninstalling intel's drivers would solve the issue till Windows wants to update and re-installs it.
My specs are:
cpu: i5-7500
gpu: intel hd 630
Ram: 8gb
OS: Windows 11 Pro 21H2 64 bits
Alberto_R_Intel
HardwareProvis, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the complete model of the motherboard?
Did you build the PC?
Was the Intel® Graphics Command Center working fine before in reference to the "Display Numbers" on this specific machine?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
HardwareProvis
This is the complete pc: https://support.hp.com/gb-en/document/c06047054
No, we didn't build the pc is a prebuilt one.
No, It wasn't working correctly since the second "Monitor" (signer) was pluged in via USB.
We reinstalled the OS and drivers.
Work enviroment.
I'll upload the SSU report the moment I get it.
Alberto_R_Intel
Hi HardwareProvis, Thank you very much for providing that information.
Perfect, no problem at all, take your time and once you get the chance please provide the SSU report so we can further asist you with this matter.
Albert R.
Alberto_R_Intel
Hello HardwareProvis, I just wanted to check if you are able to provide the SSU report and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello HardwareProvis, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
