22013 Discussions
Zenless Zone Zero Frame Drop (a770)
Olive552
frame drop in towns or battles
Unity-based games performance is not good.
젠레스 존 제로에서 마을,전투시 간헐적 렉이 발생합니다.
해당 게임뿐만 아니라 유니티 기반게임에서 대부분 렉이 발생하는데
비슷한 체급의 그래픽카드를 사용했을때는 없었던 현상이라 유니티 엔진을 사용하는
게임들에 대한 드라이버 수정이 필요합니다.
Senkuchan
Valued Contributor II
Have you tried performing a ddu and installing the latest graphics driver?
RonaldM_Intel
Hi @Olive552
Please be informed that I can only support you in English. I have used a web translation tool to translate this response hence, there may be some inaccurate translation.
Could you please be more specific on what are the performance results you are obtaining? Do you have an average FPS result or frame-time data? I suggest checking this link under the "Performance issues" section and provide us with your CapFrameX data - this can help us properly address your concern. In addition please upload the Intel SSU report from your system so I can evaluate different aspects of it such as GPU, CPU, OS and drivers.
I went ahead and tested the game running it at 4K/High presets (even though the Arc A770 generally targets 1440p High/Ultra settings) and got fairly stable gameplay experience without lagging (I'm attaching the .JSON files from CapFrameX for reference). See test video here: https://youtu.be/l3zYlllAlAk
Combat - performance test results:
Street/Town - performance test results:
Finally the recommendation from @Senkuchan is accurate, please make sure you are using the latest driver - to date it is version 32.0.101.5971.
Ronald M.
(Virus scan in progress ...)
Germina
Hi, I plan to buy an A770 and I mainly play Zenless Zone Zero plus I'm also planning to stream. I clicked on your test link but unfortunately it is unavailable. Could you reupload it for me? I want to check how it's performance. Thank you in advance.
RonaldM_Intel
Hi again,
I would like to follow up with you and check if you saw my previous message.
Please update to latest driver 32.0.101.5972 and if the issue persists provide the CapFrameX data of your session so I can analyze it and try to figure out what is causing the difference in performance.
Ronald M.
