22745 Discussions
about memory leak using i965 dri driver.
choi__bumsu
I'm developing javafx application running on linux.
When I run application, memory leak is occured.
But if I change graphic card from intel to nvidia or set Dprism.order=sw option, there is no memory leak.
I think it's problem of mesa intel i965 dri driver.
When I googled, I found similar cases.
https://www.google.com/search?newwindow=1&rlz=1C1OKWM_koKR841KR841&biw=1663&bih=866&ei=rROvXMT0D8mwmAWHqIzQBw&q=javafx+intel+hardware+acceleration+memory+leak&oq=javafx+intel&gs_l=psy-ab.1.0.35i39l2j0i203l2j0i20i263j0l5.172430.179750..181189...14.0..0.154.3603.0j26......0....1..gws-wiz.....6..0i71j0i7i30j0i8i7i30j0i7i10i30.Cf1z32byefI
Would you check this?
OS: ubuntu 17.10 32 bit
Wil.
