22930 Discusiones
bluescreen video_tdr_failure igdkmd64.sys after update from windows 8.1 to windows 10 on intel hd graphics 4600
BEhrl
Principiante
11.637 Vistas
Yesterday i updated my gaming notebook from windows 8.1 to windows 10. Overall it works fine but i got now 2 times a bluescreen telling me video_tdr_failure and igdkmd64.sys which as far as i knows means a problem with my intel hd graphics 4600.
Anyone has any idea how to solve this?
When i try to search for an update it tells me i have the knewest but the intel homepage says the newest is 15.xxxx which i cant download cause it tells me error:page not found and the driver is english while i have german drivers
0 kudos
16 Respuestas
APalm4
Principiante
10.186 Vistas
I am having the same problem. I made a post about it yesterday but so far nobody has answered.
Empleados
10.186 Vistas
I also have the same problem. I've tried all the drivers from intel and solve this problem. Meanwhile comeback win at 7 before it tunes.
Allan_J_Intel1
Empleados
10.186 Vistas
All:
This information is intended to all Windows 10 users that are experiencing issues with a supported Intel® Graphics Controller (http://www.intel.com/support/graphics/sb/CS-034343.htm supported graphics)
/message/321854# 321854 Re: -NEW- Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 10 64-bit 15.40.4.64.4256
See post # 93
Allan.
TLund2
Principiante
10.186 Vistas
I have full update my Intel HD 4600 to win 10 64 bit drivers and still get the problem
Empleados
10.186 Vistas
Neither version of 4279 does not solve the problem. Only blue death does not occur, but a window appears that the driver was restarted.
gbhj
Nuevo Colaborador I
10.186 Vistas
if you still have the memory dump (c:/windows/memory.dmp) you can use windbg to post more info about the cause of the crash
http://www.instructables.com/id/How-to-Analyze-a-BSOD-Crash-Dump/?ALLSTEPS How to Analyze a BSOD Crash Dump
Empleados
10.186 Vistas
JHeym1
Principiante
10.186 Vistas
Since nobody has done a dump analysis, here is mine. Please let me know if this helps.
Probably caused by : ntoskrnl.wrong.symbols.exe ( nt_wrong_symbols!560CA418852000 )
Followup: MachineOwner
************* Symbol Path validation summary **************
Response Time (ms) Location
Deferred 1.SRV*C:\Windows\symbol_cache*http://msdl.microsoft.com/download/symbols http://msdl.microsoft.com/download/symbols
0: kd> !analyze -v
* Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: ffffe001a0801010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff80053f06560, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 000000000000000d, Optional internal context dependent data.
Debugging Details:
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** must point to .pdb files that have full type information...
Allan_J_Intel1
Empleados
10.186 Vistas
I have been using Windows(R) 10 for a while on Intel® HD Graphics 4600, I have received this message couple of times so far, but nothing to worry about, I just ended up restarting the computer and the machine kept working properly. I am currently running the latest video drivers version 4300 https://downloadcenter.intel.com/download/25484/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Graphics Driver for Windows® 7/8.1/10* [15.40]
Allan.
PSton2
Principiante
10.186 Vistas
Hi Allan, a couple of Blue Screens might be OK with you but I get them at least 4 or 5 times a day. It is mostly when I am using graphics intensive programs like AutoCAD. This Windows 10 issue has remained unresolved for too long please please don't sweep it under the carpet - fix the problem!
Allan_J_Intel1
Empleados
10.186 Vistas
This driver crashing issue has been escalated to our engineering team, we are just waiting for any update on this matter. I still do not have an estimate time of resolution but I will come back as soon as possible.
Allan.
PSton2
Principiante
10.183 Vistas
Hi Allan,
thank you for escalating the issue.
here are the details of my system and graphics for your engineering team's reference;
TLund2
Principiante
10.183 Vistas
HIkhs
Principiante
10.186 Vistas
i'm having the same problem here. my device is ASUS X450 JF
the problem begins when i'm playing a game and suddenly gray grains appears on the screen and then BSOD with video_tdr_failure.
After that i couldn't enter normal windows mode because the screen freezes and grainy, i tried entering safe mode via cmd from installation disk and uninstalled the driver from device manager and restarted it. now i can enter the normal mode, however after trying to install intel graphics driver the problem still persists until now. I tried to install driver from intel driver update app with newest driver , the same. tried to install driver that's given from their website ( total of 4 different driver ) still the problem persists, and now the BSOD occurs in the middle of installing the graphic driver. every single time. i wonder is this a hardware problem? because i tried using win 10 and win 8 , still the same problem existed.
BTW, i'll post my dump files later, still trying to crack this problem before taking it to service center\
thanks
Empleados
10.183 Vistas
As I wrote earlier. When you quit the game World of tanks information window will pop up.
It will happen just by accident once in a while.
Even more information for you. In Windows 7, the problem is not. This problem is only after upgrading to Windows 10. If I return back to 7 problem again is not. This means that the problem is associated with win10.
/servlet/JiveServlet/showImage/2-359486-248954/intelproblem.jpg
Intel(R) HD Graphics 4600
Datum zprávy: 14. prosince 2015
Čas zprávy [hh:mm:ss]: 8:35:52
Verze ovladače: 20.19.15.4326
Operační systém: Windows* 10 Pro (10.0.10586)
Výchozí jazyk: Czech (Czech Republic)
Fyzická paměť: 8108 MB
ID dodavatele: 8086
ID zařízení: 0416
Revize zařízení: 06
BIOS grafického adaptéru: 1035.0
Aktuální rozlišení: 1920 x 1080
Procesor: Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz
Rychlost procesoru: 2494 MHz
Používaná procesorová grafika: Intel(R) HD Graphics 4600
Verze shaderu: 5.0
Verze rozhraní OpenGL*: 4.3
Verze rozhraní OpenCL*: 1.2
* Microsoft DirectX* *
Verze modulu runtime: 12.0
Verze podporovaná hardwarem: 11.1
* Zařízení připojená ke grafickému akcelerátoru *
Aktivní displeje: 1
* Integrovaný displej *
Typ displeje: Digitální
Protokol DDC2: Podporováno
Gamma: 2,2
Typ konektoru: Integrované rozhraní DisplayPort
Typ zařízení: Integrovaný displej
Maximální velikost obrazu
Šířka: 13,39 palců
Výška: 7,48 palců
Podporované režimy
1920 x 1080 (60p Hz)
Nezpracovaná data EDID:
00 FF FF FF FF FF FF 00 0D AE C4 15 00 00 00 00
28 17 01 04 95 22 13 78 02 EF 05 90 54 52 93 29
25 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 5E 35 80 96 70 38 14 40 2C 1C
24 00 58 C1 10 00 00 18 00 00 00 FE 00 4E 31 35
36 48 47 45 2D 45 41 42 0A 20 00 00 00 FE 00 43
<p style="font-size: 13px; font-family: intel-clear, arial, helvetica, 'helvetic...
Allan_J_Intel1
Empleados
10.186 Vistas
Intel is currently investigating the issue and the engineering team is working towards a resolution. I will update this thread when I get additional information.
Allan.
Responder
