hi team,
could you please help out with the answer for the question from the topic title?
A similar question was asked & Sebastian answered here, but I`m asking from a bit of a different angle.
community.intel.com/t5/Graphics/%C4%B0ntel-Hd-Graphics-620-120hz/m-p/1242212#M92978
the reason I`m asking this again after reading Sebastian's answer from the link above, is, that he was stating:
"1080o @ 120 or 144Hz need a bandwidth of 7.46 Gbps or 8.96 Gbps respectively, so the bandwidth via HDMI is not enough. " he meant here the 1.4 HDMI
now my question from a different angle, is: what about the following scenario:
running on a laptop: Lenovo ThinkPad T590 - with UHD Graphics 620, connected then to a: ThinkPad USB-C Dock Gen 2 and then connecting a monitor with say 120Hz capability.
would this work?
I'm thinking about the following scenario:
using the USB 3.1 Gen 2 (10 Gbps) cable to connect laptop to ThinkPad USB-C Dock Gen 2 and then from the Docking station to connect through as well a USB 3.1 Gen 2 (10 Gbps) to a monitor that supports 120Hz.
by doing so, theoretically can one surpass the problem of the 1.4 HDMI limitation of data transfer mentioned above.
thanks in advance for a clarification answer
Silviu
hello,
thought it would make sense to post my test results:
machine used: Lenovo ThinkPad T590 (with UHD Graphics 620)
desired result: connect & deliver higher refresh rate than 60 Hz connecting it with such a monitor at 1920 x 1080 p
port limitation of machine: Lenovo ThinkPad T590 (with UHD Graphics 620) --> 1.4 HDMI
1st machine : Lenovo ThinkPad T590 (with UHD Graphics 620)
connected through thunderbolt USB-C cable
2nd machine: ThinkPad USB-C Dock Gen 2
connected through HDMI cable from HDMI 2.0 port of the Thinkpad docking station to the HDMI port of the monitor with 144 Hz at 1920 x 1080 p.
Result: worked fine
now I`m trying to find a second monitor with higher refresh rate, to check if it can deliver signal to 2 monitors at higher refresh rates. (eg. 120 Hz or 144 Hz)
all the best,
Silviu
Hello silviudx,
Thank you for posting on the Intel®️ communities. I see that you want to know the resolution supported for your Intel® UHD Graphics 620, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
- Just to clarify the resolution you want to use is 1920 x 1080 with a refresh rate higher than 60Hz using HDMI, is that correct?
- Are you able to use another port just for testing?
- Download, run, save and attach the report for the following tool Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
Hello silviudx,
Andres P.
Yes, thaelt was the question, but then I later replied in the 2nd post of this topic that I did manage to do so, by using the thunderbolt USB-C port and connecting it to a Thinkpad docking station which has 2.0 HDMI ports and through that connecting it to a monitor and it delivered the 1080p resolution with 144 Hz.
I haven t managed to try it out with 2 monitors (@144 Hz) as I didn t have the necessary hardware at hand.
Anyway, from my point of view, thread can be closed.
All the best,
Silviu
Hello silviudx,
Thank you for your response.
Happy to hear that seems the issue is fixed, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
