however I installed the last update ( igfx_win10_100.8873 ) for
win 10 2004 19041 Processor Intel(R) Core(TM) i5-10400 CPU @ 2.90GHz 2.90 GHz
Installed RAM 16.0 GB (15.9 GB usable)
i still cant access graphic control panel in control panel
or even graphic properties in right click.
please help
Please check in Start Menu under letter "I". You should see there Intel Graphics Command Center (IGCC). It is available now only there.
Leon
thanks for responding
yes its there .
but why it is not in my right click.
"but why it is not in my right click"
You can thank Microsoft for having it removed.
then nothing bad on my new pc if its not there on right click ??????
correct. microsoft had the context menu removed with the implementation of the DCH graphic driver.
