bonjour
Voila mon soucis quand j utilise certaines applications j ai un carre multicouleurs qui s'affiche sur l ecran ce qui augmente la resolution de l'ecran ce qui veux dire que mes applications plantent mon ordinateur comment regler ce probleme merci par avance bonne journee
You have provided no information about your system. So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
