23087 Discussions
ddr3 1333 & P45...possible or not?
guys, today I read this thing herehttp://www.intel.com/cd/products/ser...ets/393820.htm http://www.intel.com/cd/products/ser...ets/393820.htmSupports dual channel DDR3 memory bandwidth up to 17 GB / s ( DDR3 1066 dual 8.5 GB / s) and 8 GB maximum supported memory for faster response times and system support for 64-bit computing.but then if I buy the ddr3 1333 and a mother board P45, P45 probably will not recognize the ram, or they work up to 1066 maximum?in this case for the DDR3-1333 - it is better to focus directly on X38 chipset 1333 or X48 chipset 1600MHz?the greater or lesser bandwidth can also be a factor of greater or lesser compatibility?thanks max
information for the comunity:
I solved the problem with the MSI P45 Diamond fantastic.
This motherboard also can drive the low voltage to kingston ddr Vram 1.25volt
