22656 討論
display driver intel graphics accelerator drivers for windows 8(r) stopped responding and has successfully recovered
員工
8,238 檢視
ok i need help.....
I using Window 7 Ultimate 64Bit Intel Core(TM) I5
My computer keep freeze or black out when i play online gaming even i restart my computer it still happen.
The display adapter I have is:Intel(R) HD Graphics
0 積分
9 回應
員工
6,222 檢視
The following resolved that issue for me for the time being, although it's not a fully satisfactory solution:
I deinstalled the graphics driver and deactivated my network adapter, then restarted the computer. Windows then automatically installed a Standard VGA Graphics adapter. I subsequently reactivated by network adapter.
The reason for deactivating the network adapter before restarting Windows and reactivating it after the automated installation of the standard driver is that Windows would otherwise automatically have downloaded and installed the Intel graphics driver, which caused this issue.
I suppose this solution ain't satisfactory if you're looking to play games with high requirements.
NICHOLAS_F_Intel
6,222 檢視
Hi Weihan,
Can you post a copy of your dxdiag please? Start -> Run -> dxdiag -> Save All Information. Just paste it here and I'll take a look.
-Nic
員工
6,222 檢視
Sorry Nic,could you help me on this issue.I faced same problem as this topic when I play FIFA 13.I had done the microsoft NET Framework update.But this problem still unsolved.
System Information
Time of this report: 3/26/2013, 01:13:08
Machine name: TOSHIBA-PC
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_gdr.130104-1435)
Language: Chinese (Simplified) (Regional Setting: Chinese (Simplified))
System Manufacturer: TOSHIBA
System Model: Satellite L510
BIOS: InsydeH2O Version 1.10
Processor: Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz (4 CPUs), ~2.1GHz
Memory: 2048MB RAM
Available OS Memory: 1910MB RAM
Page File: 1284MB used, 2536MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) Graphics Media Accelerator HD
Manufacturer: Intel Corporation
Chip type: Intel(R) Graphics Media Accelerator HD (Core i3)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_FF161179&REV_02
Display Memory: 763 MB
Dedicated Memory: 64 MB
Shared Memory: 699 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: SEC3741
Native Mode: 1366 x 768(p) (59.998Hz)
Output Type: Internal
Driver Name: igdumdx32.dll,igd10umd32.dll
Driver File Version: 8.15.0010.1986 (English)
Driver Version: 8.15.10.1986
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 10/30/2009 11:06:22, 550912 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4306-11CF-0B75-1CDFA2C2C535}
Vendor ID: 0x8086
Device ID: 0x0046
SubSys ID: 0xFF161179
Revision ID: 0x0002
Driver Strong Name: oem4.inf:Intel.Mfg:iILKM0:8.15.10.1986:pci\ven_8086&dev_0046&subsys_ff161179
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=Video...
NICHOLAS_F_Intel
6,222 檢視
Hi Tan Hong Shae - let's see what we can do here.
First; try updating your BIOS to the latest version, installer is here; http://cdgenp01.csd.toshiba.com/content/support/downloads/sll0v150.exe http://cdgenp01.csd.toshiba.com/content/support/downloads/sll0v150.exe
Then try updating your display driver to the latest we provide: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521&lang=eng Download Center
Let me know how it goes!
-Nic
員工
6,222 檢視
Thanks Nic for the solution.
IHISI not support current BIOS.
This message shown when I try to update my BIOS.
Afterwards the first try was not successful,I try to update Intel graphics drivers.But problem still occur.
Tan
NICHOLAS_F_Intel
6,222 檢視
Hi Tan Hong Shae,
Did the display driver install? Also, what's the exact/full make/model of your Toshiba* Satellite 510? There should be more characters after the 510 I believe.
-Nic
員工
6,222 檢視
Hi Nic,
I had installed latest display driver.The problem has been solved.
Thanks for the help and much appreciate it.
Tan
CLang10
初學者
6,222 檢視
Hi, Nic,
I'm facing the same issue: display driver intel graphics accelerator drivers for windows 8(r) stopped responding and has successfully recovered. Please help!
This happens every time I try to load my Sony Vegas 12. And when the error appears, my Sony Vegas stops loading. Below is my dxdiag:
System Information
Time of this report: 4/24/2014, 22:07:17
Machine name: GEEJAY-LAPTOP
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_gdr.131030-1505)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire M5-583P
BIOS: V2.21
Processor: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz (4 CPUs), ~2.3GHz
Memory: 6144MB RAM
Available OS Memory: 6024MB RAM
Page File: 6371MB used, 3821MB available
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Devices
Card name: Intel(R) HD Graphics Family
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0A16&SUBSYS_079B1025&REV_09
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Monitor Id: AUO31EC
Native Mode: 1366 x 768(p) (60.016Hz)
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3277 (English)
Driver Version: 10.18.10.3277
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Date/Size: 8/19/2013 19:20:32, 12090368 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4956-11CF-587F-9127B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0A16
SubSys ID: 0x079B1025
Revision ID: 0x0009
Driver Strong Name: oem5.inf:5f63e5341cc65b69:iHSWM_w81:10.18.10.3277:pci\ven_8086&dev_0a16&subsys_079b1025
Rank Of Driver: 00DA0001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
{5A54A0C9-C7EC-4B...
員工
6,222 檢視
Ps for the late reply
System Information
Time of this report: 3/8/2013, 21:48:18
Machine name: OWNER-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
System Manufacturer: BIOSTAR Group
System Model: H61MHB
BIOS: BIOS Date: 12/20/11 17:53:05 Ver: 04.06.04
Processor: Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz (4 CPUs), ~3.0GHz
Memory: 8192MB RAM
Available OS Memory: 8104MB RAM
Page File: 3082MB used, 13124MB available
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Sound Tab 2: No problems found.
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0152&SUBSYS_110D1565&REV_09
Display Memory: 1696 MB
Shared Memory: 1632 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: AOC 2350
Monitor Model: 2350
Monitor Id: AOC2350
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2932 (English)
Driver Version: 9.17.10.2932
DDI Version: 11
Driver Date/Size: 12/14/2012 02:42:34, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4212-11CF-A17D-0731B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0152
SubSys ID: 0x110D1565
Revision ID: 0x0009
Driver Strong Name: oem12.inf:Intel.Mfg.NTamd64:iIVBD0:9.17.10.2932:pci\ven_8086&dev_0152
Rank Of Driver: 00E02001
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
回覆
