21803 Discussions
driver old
ninowebs
Dettagli del dispositivoCompatibilità adattatoreProcessore video
Scheda grafica Intel® HD (Core i3)
ho un vecchio driver
ProviderVersionDate
26/11/2012
version 8.15.10.2900
il mio grande problema
AlHill
No, replacing the processor will do you no good.
Look on that auction site for nvidia cards, like a GT 1030 or GTX 1060 for the best price.
Remember, you are purchasing old, used equipment.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
ninowebs
thi my file
AlHill
You have multiple problems.
First, you have a 1st gen processor.  There is no Windows 10 or Windows 11 driver from Intel.  All you have is the Microsoft generic driver which lacks features and performance.
Second, your processor is not supported by Windows 10 or Windows 11.   Why are you even running Windows 11?
It is time for you to replace your hardware with a new or newer system, that is supported.
ninowebs
thanks for the support, I can't change hardware now, what do you recommend? I tried to put windows 10 but the problem is not solved
one more thing., but wouldn't it be enough to buy a video card then?
AlHill
Getting a video card is just throwing away your money.  Your processor is not supported by W10 or W11.
Now, if you have an available PCIe x16 slot, and can find an older nvidia card, yes, you can probably limp along.  I say nvidia because you have a better chance of success than with an AMD card.
You wil find that trying to keep old hardware operational will cost more than replacing the hardware.
ninowebs
this is the result of buying used PCs....ok, excuse my ignorance, but what expense should I face? can i just replace the processor? I should I replace something else?
AlHill
Jean_Intel
Hello ninowebs,
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and helped. You may also find the Discontinued Products website, website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued".
Jean O.
ninowebs
ok, I understand well, thank you all, thank you very much.
