22929 Discussions
dying light the beast bug on intel iris xe
viituuu
I came to report a bug that occurs in the new dying light, which is another one of those rendering bugs that can be solved (I think), the bug is that the game turns all red, but the bug only occurs in the open world, in closed places the bug does not happen.
https://youtu.be/44biTNIFby4?si=z6GEY2-lLGMsD_42
Here is the link to the video that shows the exact problem, from minute 5 you will be able to see that the bug only occurs in open areas
the game was tested on the latest driver and these are my settings:
CPU: I5 1135g7
GPU: intel iris xe graphics
RAM: 16GB 3200mhz
SSD: 256 NVMe
pirani123
@REDHAWKRIKER
Yes, after the game update version, there is also a red screen bug in the 3222 driver
Dhruv2
Intel helped in optimization of game for their processors they can fix it if they want
DinkoRhoades
I have just rolled back the drivers to 3222 through the site catalog.update.microsoft.com
I also changed the video settings file for the game to the lowest possible to be playable, there is no more red screen and the game is playable from 30 to 40 fps
Specs:
I5-1335u
Iris Xe
16gb ddr5 ram
leo34
I used AI to ask about the issues with this game, and the answer is as follows: 1. The correlation between community user feedback and red screen problems
● Feedback from some users: Some community users have reported that the red screen issue has been alleviated after updating to the 32.0.101.7028 driver, which may be related to video memory management optimization. However, not all users have solved the problem.
Unrepaired case: Users still report persistent red screen issues, especially in high load scenarios such as battles or complex lighting effects
2. Possible causes and temporary solutions for the red screen issue ● Root cause analysis:
Insufficient graphics memory (recommended 8GB or more).
Compatibility issues between drivers and gaming bows/engines (such as DX12 rendering conflicts).
Temporary plan:
Reduce the resolution to 720P, turn off anti aliasing and dynamic blur.
Add the game startup parameter - lowmem.sm4 to force low graphics memory mode 67.
DinkoRhoades
The lowmem.sm4 startup perameter helped with a few fps, my game was already on 1280x600 but after going back to the 7076 drivers the red screen is back.
So I am back to 3222 now and with a bit better performance due to the low mem startup.
Thank you
REDHAWKRIKER
Did anyone w
Switch to dx11 I see it's an option in the settings
Alexandre7
vamos ficar sem uma correção desse bug? meu pc roda o jogo, mas por causa deste bug nao consigo jogar, mesma coisa com o the last of us 2, mas foi resolvido depois de um tempo, mas o  caso do dying light the beast, vamos ficar sem resposta e ser tratados como minoria apagada?
Alexandre7
vamos ficar sem uma correção desse bug? meu pc roda o jogo, mas por causa deste bug não consigo jogar, mesma coisa com o the last of us 2, mas foi resolvido depois de um tempo, mas o caso do dying light the beast, vamos ficar sem resposta e ser tratados como minoria apagada?
leo34
@pirani123
I tried installing the 3222 driver and there was no red screen bug. Thank you
