20971 Discussions
enregistrement video
AZIZ007
Bonjour, j’aimerai demander votre aide pour pouvoir enregistrer des vidéos via Intel graphics, j’arrivais à le faire l’année passée, mais depuis la mise à jour que j’ai faite je n’ai plus l’onglet de capture vidéo. J’ai mis en fichier une image de la version actuelle. Merci!
Version du pilote : 30.0.100.9805
Carlos_L_Intel
Hi @AZIZ007,
Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you. Please help me with the following information in order to assist you:
  • What is the model of your graphics adapter or the model of you processor?
Carlos L.
AZIZ007
Hello my friend, sorry for the late, this is my processor model: ntel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz   1.20 GHz
Carlos_L_Intel
Hi @AZIZ007,
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Carlos L.
Carlos_L_Intel
Hi @AZIZ007,
Thank you for the information. Gaming related features have been moved from Intel® Graphics Command Center to our newest gamer focused user interface, Intel® Arc™ Control. I would recommend trying In Arc, however, it requires an 11th Generation Intel® Core processor or newer or an Intel® Arc™ Dedicated Graphics card.
A workaround I can suggest is trying the Intel® Graphics Command Center BETA: https://apps.microsoft.com/store/detail/intel%C2%AE-graphics-command-center-beta/9NMR79ZTJFTC
Let me know if that works for you.
Carlos L.
AZIZ007
Hi Carlos, i tried your solution and it’s works, thank you a lot! Now I can make tutorials with my screen recording.
Thank you so much
Carlos_L_Intel
Hi @AZIZ007,
Thank you for the update. I'm glad it worked for you, and also happy you can continue with your tutorials. Keep up the good work.
 For now, is there anything else we can do? Or should we close this thread?
Carlos L.
Carlos_L_Intel
Hi @AZIZ007,
Carlos L.
AZIZ007
Bonjour Carlos, désolé pour le retard, oui nous pouvons fermer le post, mon problème est résolu. Je n’ai aucune préoccupation. Merci beaucoup!
AZIZ007
Hello Carlos, sorry for the late, yes we can close the post, my problem is solved. I don’t have any preoccupation. Thank you so much!
Carlos_L_Intel
Hi @AZIZ007,
 I am happy everything is working well for you. For now, we will proceed to close this thread.
Carlos L.
