23272 Discussions
gma 3150 external monitor resolution problem
Good day,ladies and gentlemen.
I have MSI Wind notebook (10'' display, optimal resolution 1024x800) with onboard video Intel GMA3150 and old CRT monitor ViewSonic V775 (17'', optimal resolution 1600x1200). The problem is in the low resolution on external monitor that is connected via VGA port. The resolution can't be setted up higher than 800x600 even in single display mode with external monitor as active.
BUT after reinstalling Windows and video drivers I can configure monitor as I need... Only once. At next run videocard sets SVGA again.
I want to know about any way to fix it.
Thanks in advance.
P.S.
Please sorry my terrible english.
DArce
Valued Contributor III
a) We suggest you to install the latest monitor drivers, load the latest BIOS for your computer and use the latest video driver provided by your computer manufacturer (or test with the generic one posted on our site). You may also test using another video monitor and cable.
In addition, review the technical information posted on this article:
http://support.intel.com/support/graphics/sb/CS-022544.htm http://support.intel.com/support/graphics/sb/CS-022544.htm
If the issue persists, contact your netbook manufacturer directly for further assistance on this issue.
In
