23092 Discussions
graphic intel hd5300
leaf9
hi i use asus zen book ux305fa
no auto updates to graphics card for 4 plus years
current driver 20.19.15.4549
have found manually
driver 20.19.15.5166
can i use this driver/is it safe/ can i back up old driver in case of problems
thanks
leaf9
Stefan3D
4549 comes from Microsoft, then you have 4 older drivers at ASUS and 6 more drivers at Intel to choose from.
If you install the new driver without uninstalling the old driver, then Windows keeps a copy at
c:\Windows\System32\DriverStore\FileRepository\
Jose_V_Intel
Hello leaf9,
Thank you for posting on the Intel Community.
Based on the information that you provided I want to recommend you the following:
  • It is important to know that is recommended to use the original equipment manufacturer drivers, since they are the ones who build your system and know the components and the structure they have, also they release firmwares, patches and drivers for every system to work correctly, the ones from Intel are the generic ones.
  1. Right-click the Windows Start button. Select Device Manager.
  2. Expand the section Display adapters.
  3. Identify the Intel Graphics device among the options listed.
  4. Access the Download Center, search for the Intel Graphics model identified in step 3 using the Search box located in the top-right corner.
  5. Select the driver from the list that is designated for Windows® 10.
  6. Download the .exe file.
  7. Disconnect from the internet to make sure the driver will not be automatically updated by Windows.
  8. Go back to the Intel Graphics entry in Device Manager.
  9. Right-click on Intel Graphics and click Uninstall.
  10. In the device removal dialog box, check Delete the driver software for this device and click OK.
  11. Restart the computer after the uninstallation is complete.
  12. Open Device Manager once more.
  13. Expand the Display Adapter section again.
  14. If the graphics entry still displays Intel Graphics, repeat steps 8-11.
  15. If the graphics entry displays Microsoft Basic Display Adapter, run the previously downloaded .exe file to install the driver.
  16. Reboot the computer when prompted.
Regards.
Jose V.
Jose_V_Intel
Hi leaf9,
Let me know if you need more assistance.
Regards.
Jose V.
Jose_V_Intel
Hello leaf9,
Regards.
Jose V.
