22981 Discussions
how could i solve my problem with my GPU 6pin(REALLYE NEED HELP)!!!
pelpi1
hello everyone
i have bought 3 months ago a new hp pavilon gaming computer with a gtx 1050ti with no 6pin connectors a i5 8400 2x8 gb ram at 2666mhz a dps-310ab-3 a as pc power supply and a Intel H370 as motherboard and decided to upgrade to a new gtx 1060 6g b but this one does need a 6 pin connectors but the chipset is weird and buying a new power supply wouldnr work because it has speciale pin connected with the chipset so i dont know which model of power supply i should buy please help
King regards, a random pc user
n_scott_pearson
You can sometimes get away with an adapter that looks like this:
4-pin to 6-pin.jpgThese can be purchased most anywhere (Amazon, etc.).
Hope this helps,
pelpi1
thanks for the answer, its a premade pc so they didnt put it because the 1050 ti can work without a 6 pin idk what to do honestly
Stefan3D
Find a "repair cafe" in your area where someone can solder you a custom adapter.
