Community
cancel
Showing results for
Search instead for
Did you mean:
EGrit
how do you change the language in iGCC i cant find it
when i downloaded iGCC it was russian for some reason
Leonardo_C_Intel
Hello EGrit Thank you for posting in the Intel Community. • The Intel® graphics command center (IGCC) would work with the Operating System (OS) language, was the OS installed on Russian by any change? • Do you have any other languages set on Windows settings languages? if you do can you delete them and uninstall and install the IGCC on the system? • In order to help you better, I would like to gather more information about the configuration you have on the computer. Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility • Steps to save the report: 1- Run the utility. 2- Click on “Scan” to get the scanned system. 3- Once the scan is complete click on “next”. 4- Use the “save” option, save the report to your desktop. 5- To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello EGrit Have you followed the steps provided and collect the information retested? Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
Hello EGrit I haven’t heard back from you, I am going to close this request If you have more questions please do not hesitate in replying back. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
