22680 討論
i7 8700k Intel Graphics Installation Error with MB Gigabyte Z370P D3
JPalu
初學者
2,752 檢視
After installing all the drivers on my new desktop, I couldn't install HD Graphics driver on my i7 8700k.
It returns "this system does not meet the minimum requirements for installing the software" error.
I'm running Windows 10 Pro version, MB Gigabyte Z370P D3, and 2x 8GB 2400MHz DDR4 Non-ECC CL15 DIMM HyperX FURY Black Series
Also, I tried all the Driver versions. Update all W10, update inf.drv, not Bios, because on MB is v. from 10/05/2017 and on the support MB Gigabyte is last from 2014/08/25. What next?
0 積分
2 回應
Stefan3D
榮譽貢獻者 II
1,582 檢視
I see you already reviewed similar issue at
Do you actually see the iGPU in device manager?
If so, try
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
JPalu
初學者
1,582 檢視
Problem solved. After 2 day actualizaciones last actualization W10 it solved. Driver for VGA successfully install. Thx.
回覆
